[ROM] Jellybean 4.2-Eternityproject - CyanogenMod 10.1 for LG Optimus 4x-hd
Ragazzi, è appena stata pubblicata la prima beta della CyanogenMod 10,1 (Jelly Bean 4.2) per il nostro terminale, a seguire riporto il link della pagina ufficiale dello Sviluppatore (Kholk), dove troverete istruzioni e link per il flash:
http://www.eternityproject.eu/topic/...optimus-4x-hd/ Inviato dal mio LG-P880 usando Androidiani App
R: [ROM] Jellybean 4.2-Eternityproject - CyanogenMod 10.1 for LG Optimus 4x-hd
se ho capito bene bisogna usare un'altra recovery per flashare la CM10.1:
http://forum.xda-developers.com/atta...4&d=1359486923
però io aspetto un pò prima di flasharla perchè voglio leggere qualche feedback
Ancora un po acerba meglio aspettare qualche release ;)
Hey guys!
I've solved some issues.
The vibrator now works perfectly here and there was a performance problem.
The performance problem was related to OpenGL ES 1.1 not running really fine and the Camera app running slow because it was falling back on SW video processing. Now it works perfectly and fast as hell here.
As for the "Android Beam" menu, I've got some ideas on how to activate it (even if actually NFC works wonderfully).
I've read that an user says something about no autofocus on Camera: I can only say it's working fine here, I've practically stressed the focuser to get a bug, but nothing, my device focuses correctly.
Another thing: ROOT.
I may know why root isn't working and yeah, I was referring to ADB root access, not to users root access when I said it was working for me. I left enabled some developer-only "flags" that will make some mess here and there (and also lower the performance).
So, the next version will be released tomorrow and will contain:
- Vibration fix (done. -- damn proprietary things to reverse engineer!!!)
- HW Video Decoding (done)
- 3DHW Fix for OpenGLES 1.1 (done)
- Easy root access for users (ToDo -- simple)
- Option in settings for deactivating NFC (Not sure!)
That's all for now.
The EternityProject Team Manager & Main Developer,
--kholk
