Carlo volevo farti i complimenti per l'impegno che stai dimostrando...
Anche se non uso ics seguo lo stesso le discussioni..
:thumbup:
Inviato dal mio Optimus 2X
:thumbup:
Grazie Vis
La Rc-08 è fuori e questo è il changelog:
Updated to Version RC0-8
added Center Clock Patch to Additional Downloads
Changelog:
contacts: updated german translations
luni: Fix Double decrement bug introduced by strict-aliasing patch
Repurpose apparently abandoned Protips as CM Welcome hints
Merge "Settings - Updated Italian translation" into ics
Merged on Jun 16th at 14:34:47 in android_packages_apps_Settings
cm: update italian translator
Merge "recovery: Allow key to repeat on hold." into ics
Merge "make compatible with github v3 api" into ics
do not do local_manifest.xml repos
Merge "Status Bar Brightness Control Padding" into ics
Merge "Japanese: initial translation for ics" into ics
Merge "Updated Hebrew Translation" into ics
Merge "LockscreenTarget : Switch to dp from px for insets" into ics
Merge "Polish translation update" into ics
Merge "Update Simplified Chinese translations Signed-off-by: yxwzyyk " into ics
Merge "Settings: Add and update pt-PT translations" into ics
Merge "Trebuchet: Added Dutch translations" into ics
Merge "Mms: Add and Modify pt-PT translations" into ics
Merge "Trebuchet: Update pt-PT translations" into ics
Settings: Updated german translation
Merge "Spanish lock screen background translations in Settings" into ics
Merge "Browser: Remove duplicate actions from overflow menu when using quick controls" into ics
Merge "Fix occasional completely mute incoming call" into ics
Merge "Phone - Updated Italian translation" into ics
Merge "Fix long click intent for Wimax notification pulldown / power widget" into ics
Mms: added the option to change the soft keyboard type when composing messages
Merge "PT-BR: Added missing translations" into ics
Only update UI at 1 Hz during nandroid backup/restore
Add Epicmtd to changelog
Actually set the header guard in "linux-syscalls.h".
Merge "telephony: Smdk4210RIL: clean up processUnsolicited" into ics
Fix Eclipse classpath file for ICS.
finnish: weather translations and some other fixes
Trebuchet: Updated german translation
Hungarian translation update for Change Ifcf862f9
Merge "Add the posix_memalign(3) function to bionic" into ics
Merge "Remove the meaningless on Linux if_dl.h header." into ics
Merge "Remove expired dns cache entries before removing oldest" into ics
Merge "Avoid multiple dns lookups for the same query" into ics
Merge "Revert " Trim after explicit gc."" into ics
Merge "bionic: Update fcntl.h clean header" into ics
Merge "bootanimation: performance enhancements" into ics
WebGL for the Android browser in Ice Cream Sandwich
Update to libpcap 1.3.0
Update to tcpdump 4.3.0
XXMrHyde ha appena pubblicato una versione "ricca" della sua rom, contrariamente ai suoi iniziali intenti di lasciarla pulita.
Il suo lavoro promette bene.
Questo il changelog e le indicazioni
XXMrHyde`s CM9 Rom Special Edition (RC0-9)
This Rom is based on my Unofficial CM9 Build RC0-9,
(this Rom is NOT an Update of my Unofficial CM9 Build),
my main priority will be the updates of my Unofficial CM9 Build.
I make this Rom to change and cutomize more, than it is possible for an Unofficial CM9 Build.
As the base Build RC0-9 of this Rom, isn`t a clean Build any more, I don`t want to release the Build RC0-9 separately.
next Unofficial Build will be RC0-10,
and will be available in a few days.
Screenshots:
Additionals/Changes:
- PDroid Framework (Original Thread, ICS Port)
- PDroid App
- Gapps are preinstalled
- Galaxy Nexus Bootanimation
- Ubuntu Font
- Center Clock Mod
- battery 0-100% Mod
- Recents Apps Theme
- Holo Red Theme
- Additional Apps (uninstallable):
- Google-Translate,
- GMail
- Youtube
- Root-Browser
- GetRil
- Holo Themed Apps:
- calendar,
- contacts
- email,
- GMail
- SMS/Mms,
- Play-Store,
- Google-Translate,
- Youtube
Download:
Solidfiles
MediaFire
Installation:
flash zip with CWM
- Full-Wipe is required,
if you come from a non CM9-Based Rom,
-Full-Wipe is recommended,
if you come from owain`s Domination Rom Build 78)
if you install via Non-Wipe, you HAVE TO deinstall the following apps:
- GMail (Play-Store Version)
- Google-Translate
- Youtube
After Installation:
- install a matching (V10) Ril with GetRil
- System-Settings -> Themes -> select XXMrHyde Theme...
Possible Problems:
The Theme can`t be applied, (This Theme was compiled... ):
- install Stock Theme,
- System-Settings -> Apps -> Tab "all" -> Theme Provider -> delete data,
- reboot
Missing assets:
- ignore error message about missing assets,
- press install
disappering Statusbar:
- force a System-message (SMS, Screenshot, ...)
NOTE:
DON`T ask for including LG O4X Lockscreen, since Lockscreen Weather and Calendar Panel is included into CM9,
the LG O4X Lockscreen Patch is broken,
and ATM I don`t get it to work
E dopo la special edition ecco la Rom rc 1-10 pulita e corrispondente ai dettami unofficial cm9
quindi subito dopo ci daranno uno zip per eliminare i fastidiosi "lag" (ritardi) una cosa messa a punto da TonyPChangelog:
Updated to the latest CM-Source,
Note: a flashable zip for adding "lagfree + dalvik fix" will be available soon
Ultima modifica di CarloIT; 27-06-12 alle 11:03
Questo il cangelog della 1-11 uscita ieri sera:
Updated to RC1-11
Changelog:
- Updated to the latest CM-Source,
- Included lagfree + dalvic fix
(lagfree script by batoo, dalvic fix by flak0, and portet to our O2X by tonyp)
- Included AOKP weather icons for lockscreen weather panel (looks a way better than the CM ones,  )
orBy (04-07-12)
CarloIT (04-07-12)
fatto e mi ha stupito!
così pulita e con il suo kernel ciano è veramente fluida e performante.. peccato solo per il supporto usb mass storage.
ci smacchino un po' e poi magari carico un'altro kernel (facendo cache e dalvik perdo q.sa??!?!)
ril è il default 218 con bb 521.. ho fatto una telefonata, scaricato 2-3 app e navigato un po' e fila tutto liscio.
il launcher trebuchet non sembra neanche più lui in termini di fluidità, in fase d'installazione ho pensato.. dovrò subito installare apex ma aspetto un pochino per le personalizzazioni e vedo come va questo dopo un paio di giorni con il lag-fix.
ciao caro!
CM9 XXMrHyde`s UNOFFICIAL Build RC1-11 - Harsh Kernel 3.0.37 P990 Build-1907 - BB 521 / RIL 218b
Bene Niko Grassie difatti e da apprezzare la pulizia del lavoro di XXMrHyde
Con cache e dal il non perdi nulla vai
Sent sometimes from my iPad using Tapatalk HD
