Screenshots:
Thanks to clashman for the screenshots
http://forum.xda-developers.com/show...42%3Cbr%20/%3E
Details of the ROM:
For use with NEW unlocked ICS bootloader only,
tested with TWRP (thanks to tonyp for his work on
TWRP!)
Multilanguage support planned, but not added yet
in this version
Does not come with gapps, you need to flash it
separately
Superuser:
Before installing anything, first activate root
permission from 'Permission' app in 'Security'
folder. Select 'manage root permission' and enable
it.
This only needs to be done once, and all superuser
prompts will come as usual when you install/use
root apps.
If you installed or tried to use any root apps before
doing this, and your app no longer gets root
access, reinstall that app.
Battery:
To see percentage battery indicator on the status
bar, go to settings->battery and change the battery
indicator style
Performance:
To make the UI transitions faster, you can use the
good old standard tip:
Go to settings->developer options
Set 'window animation scale', 'transition animation
scale' and 'animator duration scale' all to "0.5x". UI
animations will seem twice as fast after doing this.
If the ROM becomes slow over time, do a reboot.
And try not to do a lot of stuff in the first few
seconds when SD card scanning is going on, sync
is going on or when apps are updating in the
background. Its not right to complain of "this/that
doesnt work" or lag when you do that
Some cool tips and tricks to improve your
MIUI experience(taken from the official
site):
Tips, tricks and shortcuts
Download links:
Download link
http://www.mediafire.com/?fbcp3i262osb6d0
Gapps download link
http://goo.im/gapps/gapps-jb-20121011-signed.zip
Instructions:
Make a full wipe if you are coming from any other
ROM, and flash it in recovery.
Dont forget to flash the 4.1.2 gapps
Standard disclaimer:
I am not responsible if anything goes wrong with
your phone.
If someone has posted a bug and you have the
same bug, just thank their post or wait. No need to
flood with the same bug reports.
Small problems such as some app related
problems can be dealt with at a later stage.
Known issues:
Some issues with the camera (try feav's camera)
led notification lights get stuck on sometimes
Credits:
RC and the rest of the CM team for all their work
MIUI team (especially the Nexus S team and
Photon team headed by Th3bill)
wkpark for cracking the new bootloader and
making it possible to use custom ROMs with it
Pengus77 and the other devs who brought CM10 to
the new bootloader.
