Utente del giorno: bluflight13 con ben 74 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: bluflight13 con ben 224 Thanks ricevuti negli ultimi sette giorni
Utente del mese: Sfattucci con ben 1154 Thanks ricevuti nell'ultimo mese
Pagina 1 di 28 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 277
cm 10.1 by Tonyp
    Thanks
    12
    cm 10.1 by Tonyp
    Tonyp è famoso per la sua paranoid sul nostro p990.
    Ma sto seguendo con piacere il lavoro che sta facendo sulla 10.1. Secondo me è davvero interessante e non va tralasciata:
    Maggiori info:
    CM 10.1 discussion thread - xda-developers
    Thread Ufficiale:
    [ROM] CM10.1 - tonyp - T-Build 02 xda-developers
    Bug Noti
    CM10.1 specific bugs:
    • Bluetooth is accellerating on many headsets fixed (by replacing the bdroid bt stack with bluez)
    • Wifi hotspot isn't working fixed (by forwardporting the CM10 internal hotspot handling to CM10.1)
    • SDCard write speed is subpar. not fixed
    bugs affecting all CM10+ based ROMs (unordered list):
    • unable to reject calls on SU660 basebands fixed
    • low brightness after unlocking fixed
    • automatic time on SU660 and v30x basebands is broken fixed
    • wifi & 3g drain fixed (Kowalski Kernel)
    • notification lights aren't working fixed
    • zram is selected at 18% but isn't enabled fixed
    • init..rc contains some parameters interfering with the kernel configs fixed
    • bootanimation gets displayed "too long" fixed
    • CM10.1 Performance CPU settings aren't compatible with our Tegra CPU fixed
    • you can't bind the searchkey to actions like opening the recent app drawer fixed
    • FM radio isn't working fixed
    • In-Call muting fixed
    • Call forwarding fixed
    • autobrightness isn't working properly semi-fixed (kk120+ - kernel instead of ROM controlled, so you can't control it in the ROM, but via a sysfs)
    • Stock camera has some drawbacks (especially panorama & hdr) semi-fixed (by his or this ported LG Stock camera)
    • HDMI orientation is broken not fixed
    • no signal after airplane mode bug (double press data or reboot to gain it back) not fixed
    Istruzioni di Installazione:
    Updating to a newer T-Build:
    1. No wipes or system-format needed!
    2. Choose the correct ROM for your bootloader
    3. Flash the ROM
    4. Flash the latest kowalski kernel
    5. Tiny Gapps are included, so there's no need to flash gapps if those are enough for you.
      If you want the full gapps package use the non-neon one I provide here.
      If you want to remove gapps flash this package after flashing the ROM: CM10.1-gapps-remover-tonyp.zip
    6. Reboot
    Coming from another ROM:
    1. If you're on the newbl either use pengus CWM 6.0.2.5 or my TWRP!
      Other recoveries won't work.
      oldbl users can use any CWM >5 or TWRP version.
    2. Do a full wipe!
      Just do the wipe, you will be thankful afterwards when everything does run better.
    3. Format /system
    4. Choose the correct ROM for your bootloader
    5. Flash the ROM
    6. Flash the latest kowalski kernel
    7. Tiny Gapps are included, so there's no need to flash gapps if those are enough for you.
    8. Reboot
    9. Don't restore system apps (like Settings) or system data (like Wifi data) with TitaniumBackup!
    Raccomandazioni di Tonyp
    • Go to Settings - Performance - Processor and change the "Maximum CPU frequency" to 1200 (or even 1500) and "Set on Boot"
    • Open the KowalskiManager
      • enable the 3 power saving options at the top
      • lower TX Power to 11
      • Change the SD readaheads to 512
      • enable dynamic fsync
    • This ROM comes pre-configured with the following memory management changes:
      • zRAM enabled with 18%
      • tonyp memory management enabled
      • purgeable assets enabled
    Kowasky Kernel
    Nightles
    Stabili
    Thread ufficiale
    Ultima modifica di cecet23; 20-05-13 a 16:42
  2. I seguenti Utenti 3 hanno ringraziato cecet23 per il post:
    droide_volante (18-05-13),Napulitan (07-05-13),vismo (23-04-13)
    Senior Droid L'avatar di vismo
    Thanks
    141
    Quote Originariamente inviato da cecet23 Visualizza il messaggio
    Maggiori info:
    Grazie della segnalazione... Non me ne ero accorto
    Ma tu l'hai provata?
  5. #3
    Thanks
    12
    Quote Originariamente inviato da vismo Visualizza il messaggio
    No aspetto il thread ufficiale.
  6. #4
    Baby Droid L'avatar di biagio572
    LG P990
    Thanks
    12
    Appena flashata ma la bootanimation va in loop.. sinceramente non ho capito se sia per oldbl o newbl..
  7. #5
    dip
    dip non è in linea
    Thanks
    L'ho flashata pure io tutto ok
    poi ho provato a flashare le gapps aggiornate e da allora solo loop
    provati con tutti i wipe data cache e dalvik niente da fare.
    Restore su vecchia PA sempre di tonyp e ancora cell in loop
  8. #6
    dip
    dip non è in linea
    Thanks
    Ho provato in vari modi reinstallando più volte ho anche cambiato il CWM con TWRP
    alla fine ho scoperto per puro caso che basterebbe togliere la scheda sd al primo riavvio forse per leggerla la prima volta ci mette davvero tanto.
    Scusate volevo notare che questa rom è per New BL
    Ultima modifica di dip; 24-04-13 a 16:44
  9. #7
    Thanks
    12
    Ci siamo ragazzi, la versione cm 10.1 di Tonyp ufficiale:
    [ROM] CM10.1 - tonyp - T-Build 01 - waiting has come to an end [05.05.13] - xda-developers
    Ultima modifica di cecet23; 10-05-13 a 08:29
  10. I seguenti Utenti 2 hanno ringraziato cecet23 per il post:
    Napulitan (07-05-13),vismo (05-05-13)
  11. #8
    dip
    dip non è in linea
    Thanks
    La sto installando per ora tutto ok
  12. #9
    Apr 2011
    Thanks
    42
    Ma con questa ROM non funziona lo script per invertire le memorie (che funzionava benissimo con la ROM di Pengus)? se lo installo sulla rom di tonyp il cell non parte più
    Optimus Dual
  13. #10
    Androidiano L'avatar di fats
    Thanks
    26
    io venendo dalla django 1.6.5 e seguendo alla lettera le istruzioni non riesco a installarla. mi resta il logo cyano in loop. capita a qualcun altro?
  • Non puoi inserire repliche
