[ROM][ICS][NewBL/OldBL] SlimFastStockPluss
    Baby Droid L'avatar di sgspluss
    SlimFastStockPluss
    Slim=around 100MB smaller then Stock/Fast=more Smoothness and Performance/Stock=based on Stock/Pluss=with extra features
    Support New and Old Bootloader
    Last update: 14.11.2014
    If you want to support my work, you can do it here:
    Changelog:
    - Added Kowalski Kernel M1 with RamHack
    - Updated lto.dat
    - Updated Google Playstore
    - Updated Google Keyboard
    - Updated Viper4Android
    - Updated Camera
    - Deleted Cirus
    - Deleted useless libs
    - Deleted useless fonts
    - Deleted useless init.d files
    Download:
    New Bootloader
    SFSP_v3A_NewBL
    SFSP_v3B_NewBL
    Old Bootloader
    SFSP_v3A_OldBL
    SFSP_v3B_OldBL
    How to install:
    - Download Rom
    - Copy it to Internal or External SD
    - Boot the Recovery
    - Full Wipe
    - Format /system
    - Install Zip form SD card
    - Finish
    Rom Adjustments:
    How to change Swappiness via Terminal
    (setting are applied immediately and sticks after reboot)
    su [enter] swap0 [enter]
    su [enter] swap10 [enter]
    su [enter] swap20 [enter]
    su [enter] swap30 [enter]
    su [enter] swap40 [enter]
    su [enter] swap50 [enter]
    su [enter] swap60 [enter]
    su [enter] swap70 [enter]
    su [enter] swap80 [enter]
    su [enter] swap90 [enter]
    su [enter] swap100 [enter]
    How to activate Viper4Android FX
    To activate Viper4Android FX you need to install driver frist!
    Open the Viper4Android FX app and give give them root permission.
    Now you will ask to Install/Update driver, select yes.
    Now select "with VPF" and press OK.
    Reboot your phone and enjoy Viper4Android FX!
    Credits goes to:
    - pengus77 for Kowalski Kernel
    - tonyp for davik-fix
    - rugglez for ics old bootloader
    - zhuhang for Viper4Android FX
    Ultima modifica di sgspluss; 16-11-14 alle 20:55 - Motivo: Update v3
    Update from v2 to v3
    Changelog and downloadlinks as usually in OP.
    Rom information:
    If you wanna choose homescreen in settings you will get an fc.
    This happens because the lg launcher was deleted and i have not delete the line yet.
    Why? Much code, much languages this will need some more time.
    Also now you will download the rom from my own server which means,
    you will download it with fullspeed and for me it will be easier to push new updates.
    Batterysafe tip:
    Attention, this will only works with kowalski kernel, cause they include the needed governor!
    Use as Governor: interactivex as Scheduler: noop and leaf the Swappiness of 40 (standart)
    Test it yourself, this will be an good compromise between performance and batterylifetime
    Hope you wanna enjoy this rom
    After some user reprted some trubble with new downloadlinks from server, i have reuploaded it into the good old cloud.
    Now the problem is fixed and you can download it from anywhere
    Senior Droid L'avatar di kayuz
    non te lo dico :D
    un laggoso lento e cattivo LG
    Ringraziato 36 volte in 30 Posts
    really good work
    For a long time I tried the rom 4.4.4 of tonyp and DJNoXD.
    But become laggy some time after installation, so I finally decided to return to the last stock rom.
    In the past I have also tried the Optix; It worked well, but ... is not the 4.4.4 or 5 ....
    Now I read that you made also this rom.
    What is the difference between SlimFastStockPluss and Optix?
    Thanks.
