First version of the KING_2X_ROM by KING4Developers.
- Based on v20L
- Root
- Updated Superuser
- Updated bin/su
- Full deodex apps & Framework
- Original Kernel
- New framework
- Optimized ram
- Increased speed of system
- Added ringtones ICS
- Added bootanimation bios
- Added music ICS
- Added Roboto ICS font
- Added live wallaper
- Removed LG Apps
- Android Market 3.3.11
- GoLauncher 2.62
- Astro 2.0
KING_2X_ROM v1
NOTE! You should make a nandroid backup, if something goes wrong, or if you want to restore configuration and apps.
Installation procedure - Quick guide:
1) Copy the KING_2X_ROM in your SD.
2) Reboot in to recovery (ClockworkMod)
4) Do the 3 wipe (data/factory reset, cache partition, and in advanced, dalvik cache.
5) Go to Flash zip from sdcard -> Choose zip from sd card and select the KING_2X_ROM and confirm.
6) When the installation is completed, reboot your system.
consiglio di flashare anche il kernel neoblaze 280911 che trovate qui sotto:
neoblaze 280911
(convertirà il sistema in ext4 aumentando velocità, performance e permette l'OC fino a 1400mhz)
screenshot
