ChristianTroy
per il bluetooth vediamo, speriamo di riuscire a far andare i moduli...
sto leggendo l'output di "dmesg", a quanto sembra c'è il supporto per gli hub e per i gamepad xbox:
codice:
<6>[ 0.151738] usbcore: registered new interface driver hub
<6>[ 2.044990] usbcore: registered new interface driver xpad
per lo usb mass storage ho fixato, come pensavo c'era un path errato in vold.fstab, per chi voglia farlo manualmente deve:
- editare "/system/etc/vold.fstab
- sostituire questa linea "dev_mount udisk /mnt/usb_storage auto /devices/platform/usb20_otg/usb"
- con questa "dev_mount udisk /mnt/usb_storage auto /devices/platform/usb20_host/usb1"
- riavviare
come vedete ora funzia:
codice:
W/Vold ( 73): subsystem found in netlink event
D/Vold ( 73): usb, 1
D/Vold ( 73): == current usb device: 0781/5567 ===
D/Vold ( 73): scsi_device, 1
D/Vold ( 73): Volume udisk state changing 0 (No-Media) -> 2 (Pending)
D/Vold ( 73): Volume udisk state changing 2 (Pending) -> 1 (Idle-Unmounted)
D/MountService( 446): volume state changed for /mnt/usb_storage (removed -> unmounted)
D/RKUpdateReceiver( 589): action = android.intent.action.MEDIA_UNMOUNTED
D/MountService( 446): sendStorageIntent Intent { act=android.intent.action.MEDIA_UNMOUNTED dat=file:///mnt/usb_storage (has extras) }
D/MediaScannerReceiver( 670): action: android.intent.action.MEDIA_UNMOUNTED path: /mnt/usb_storage
D/VoldCmdListener( 73): volume mount /mnt/usb_storage
I/Vold ( 73): /dev/block/vold/8:1 being considered for volume udisk
D/Vold ( 73): Volume udisk state changing 1 (Idle-Unmounted) -> 3 (Checking)
D/MountService( 446): volume state changed for /mnt/usb_storage (unmounted -> checking)
D/MountService( 446): sendStorageIntent Intent { act=android.intent.action.MEDIA_CHECKING dat=file:///mnt/usb_storage (has extras) }
I//system/bin/fsck_msdos( 73): ** /dev/block/vold/8:1
I//system/bin/fsck_msdos( 73): Invalid signature in fsinfo block
I//system/bin/fsck_msdos( 73): FIXED
I//system/bin/fsck_msdos( 73): ** Phase 1 - Read and Compare FATs
I//system/bin/fsck_msdos( 73): Attempting to allocate 3820 KB for FAT
I//system/bin/fsck_msdos( 73): ** Phase 2 - Check Cluster Chains
I//system/bin/fsck_msdos( 73): ** Phase 3 - Checking Directories
I//system/bin/fsck_msdos( 73): ** Phase 4 - Checking for Lost Files
I//system/bin/fsck_msdos( 73): Next free cluster in FSInfo block (141085) not free
I//system/bin/fsck_msdos( 73): 205 files, 3333056 free (833264 clusters)
I/Vold ( 73): Filesystem check completed OK
I/Vold ( 73): Device /dev/block/vold/8:1, target /mnt/usb_storage mounted @ /mnt/secure/staging
D/Vold ( 73): Volume udisk state changing 3 (Checking) -> 4 (Mounted)
D/MountService( 446): volume state changed for /mnt/usb_storage (checking -> mounted)
D/MountService( 446): sendStorageIntent Intent { act=android.intent.action.MEDIA_MOUNTED dat=file:///mnt/usb_storage (has extras) }
Per la galleria, ce ne sono due... una è quella "Rockchip" che riproduce in HW i video, ecc; l'altra è quella ufficiale google, per il sync con picasa; prova da "Impostazioni -> Applicazioni -> Tutte -> Galleria" a cliccare "Disabilita" su quella grande 1.30MB (quella google)
Adesso vediamo se si riesce a caricare i moduli per il bluetooth... riciclando i sorgenti 2.6.32, sperem
@dondy
uso una compressione piuttosto spinta con 7zip, se la scomprimi sono quasi 500mb
