Pagina 41 di 41 primaprima ... 31394041
Visualizzazione dei risultati da 401 a 404 su 404
[ROM][Android 4.1.1 Jelly Bean]X-Team 4.12
  1. #401
    Aug 2014
    Hi,
    something did go wrong after my 3rd update of my device. I have already ask for that at the x-team blog.
    after "7_Click su Formatta e attendere il completamento" I get a finish message after some time and my device disconnect, connect and disconnect again.
    Then I guess everything is fine and I restart the device and unplugged it. Unfortunately I am not able to boot into flash mode again to proceed with "8_Click su Aggiorna"
    I tried it several times but its not possible to get into flash mode with Vol - buttom. I get always a bad USB device without VID and PID.
    USB\VID_0000&PID_0000\5&28A57818&0&2
    usb.inf:Generic.Section.NTamd64:BADDEVICE.Dev:6.1. 7601.18328:usb\unknown
    Did you know how I could get back to flash mode? After 2 successful installations of this superb rom it's the first time that I get this problem with my device.
    I already tried an other pc to exclude driver problems but it does not work it looks like I can't boot into flashmode.
    I hope you could help me
    Kind regards
    Falco
    Edit: I posted it also at androidworld.it/forum/mediacom-smartpad-810c-381/%5Brom%5D%5Bxteam-4-8%5D%5Bandroid-4-1-1%5D%5Bjellybean%5D%5Bmediacom-810c%5D-73365/index68.html#post1445521 because there are Xteam members active.
    Ultima modifica di falco2930; 24-08-14 alle 17:54
    Androidiano L'avatar di Bl4ckJ4ck
    Aug 2014
    Bari
    Asus Zenfone Go
    Aiuto!!! Il tablet quando e carichissimo dura 20 minuti dopo quando e al 50% ad un certo punto si chiude e si riapre scarico e problema della rom o del tab?
  4. #403
    May 2014
    Quote Originariamente inviato da Bl4ckJ4ck Visualizza il messaggio
    A me è successo. Devi buttare le batterie.
  5. #404
    Aug 2014
    Bari
    Asus Zenfone Go
    Quote Originariamente inviato da IlCavaliereOscuro Visualizza il messaggio
    No nulla era un problema di 1 giorno ora e passato.
    Allora.Non me lo fa connettere al pc il tablet...
    POI Ho messo la MicroSD Nuova e il tablet l'ha inghiottita..
    CHI MI AIUTA?
    Grazie.
    editata dallo staff
