Ho provato a farlo da mio seven (32bit però) e la finestrella mi riporta questo:
codice:
Device type:
1) Normal
2) Special (for example: Sony Tablet S, Medion Lifetab)
x) Unroot
Make a choice: 1
Checking if i should run in Normal Mode or special Sony Mode
Please connect your device with USB-Debugging enabled now
Impossibile trovare il percorso specificato.
Normal Mode enabled!
Pushing busybox....
Pushing su binary ....
Pushing Superuser app
Making busybox runable ...
Please look at your device and click RESTORE!
If all is successful i will tell you, if not this shell will run forever.
Running ...
Successful, going to reboot your device in 10 seconds!
Waiting for device to show up again....
Going to copy files to it's place
You can close all open command-prompts now!
After reboot all is done! Have fun!
Bin4ry
Premere un tasto per continuare . . .
e ovviamente non succede nulla
