Updated Feb 2, 2013: -
V6 SuperCharger Update 9 RC11
Added -
FixAlign! - zipalign and fix permissions all at once!
Added -
Flush-O-Matic! - Engline Flush option was revamped! The script can now dump caches automagically and can now be launched within V6 too!
Added -
Entropy-ness Enlaaaaaaaaaaaaaaaargerrrrr!!
Added - Option to run
Detailing (database optimization) after a certain number of boots (you decide how many)
Separated - Misc & 3G Tweaks
Optional - Kernel Strength / Reboot Tolerance
Tweaked - Launcher Detection (yeah... yeah...)
Added - Support for newer kernels which involved a massive revamped code of the bOOM Stick! (they now do funky stuff with the adj and app's oom_adj files)
Revamped - BulletProofing scripts (due to the new kernel thing) and *97BulletProof_Apps can also be launched within V6!
Refined - Calculated Minfrees for some devices.
Bugfix - Wheel Alignment and FixAlign skips SystemUI.apk (problematic)
Updated - Infos in all generated scripts.
Updated - Help file
Tweaked - LOTS of code and LOTS of user infos!
