Utente del giorno: complicazio con ben 10 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: fracarro con ben 35 Thanks ricevuti negli ultimi sette giorni
Utente del mese: Stahl con ben 191 Thanks ricevuti nell'ultimo mese
Pagina 47 di 86 primaprima ... 37454647484957 ... ultimoultimo
Visualizzazione dei risultati da 461 a 470 su 855
[Topic Ufficiale] CyanogenMod 7.2 Made by Squadzone
  1. #461
    Androidiani Power User L'avatar di anto999
    Camposano (NA)
    galaxy Nexus-galaxy gio
    Ringraziato 1,527 volte in 1,202 Posts
    ecco la cyanmobile experience: [quote author=Squadzone link=topic=2501.msg48668#msg48668 date=1334592997]
    [center][size=14pt][color=blue][b]THIS CM7 ROM IS BUILD FROM SOURCE WITH MODIFICATION FROM AOSP AND AOKP
    I AM NOT RESPONSIBLE FOR ANY DAMAGE DONE TO YOUR DEVICE BY FLASHING THIS ROM
    [size=14pt]THIS ONLY FOR GT-S5660 NOT OTHERS[/size]
    [size=10pt]highly recommended to charge your cell phone at least 90% to prevent failure during flashing process..[/size]
    [size=10pt]
    YOUR DEVICE MUST BE FLASH TO GINGERBREAD 2.3.4 OR ABOVE
    [/size]
    [size=12pt]ITS RECOMMEND TO PARTITION YOUR SDCARD BEFORE FLASH[/size]
    [size=14pt]CyanMobile eXperience Release 2012-06-26
    Download Link
    [/size]
    ">>>>>>>>> http://www.mediafire.com/?zcthnu45yp72fjs <<<<<<<<"
    [size=10pt]FLASH VIA CWM[/size]
    [size=10pt]MUST WIPE DATA AND CACHE[/size]
    [size=10pt]DO NOT MIRROR[/size]
    [size=10pt]DO NOT USE A2SD/S2E OR ANY SCRIPT FOR APP2SD!![/size]
    [size=12pt]
    How to Flash CyanMobile ROM :
    [/size]
    • [li] Download and copy the latest CMobile ROM to SD Card[/li]
      [li] Reboot to Recovery Mode[/li]
      [li] Select Wipe data and cache[/li]
      [li] Select install zip from sd card[/li]
      [li] Select choose zip from sd card[/li]
      [li] Select the new CMobile ROM[/li]
      [li] Select Yes - Install update[/li]
      [li] Wait until the Installation is finish[/li]
      [li] Select Wipe cache partition[/li]
      [li] Select reboot system now[/li]
    [size=12pt]
    ChangeLog :
    [/size]
    [size=12pt]
    Working :
    [/size]
    • [li] RIL (Phone & Data)[/li]
      [li] 2D & 3D Acceleration[/li]
      [li] Audio[/li]
      [li] Camera[/li]
      [li] Usb Tether[/li]
      [li] FM radio[/li]
      [li] GPS[/li]
      [li] Wifi[/li]
      [li] Wifi Tether[/li]
      [li] Bluetooth Tether[/li]
      [li] Bluetooth[/li]
      [li] USB Mount[/li]
      [li] SD Card[/li]
      [li] Compcache[/li]
    [size=14pt]SOME SCREENSHOTS[/size]
    [/quote]
    download link: update-CyanMobile-eXperience-GalaxyGio-20120626-Release.zip
    il changelog è presente nella rom.
    NB non funzionano a2sd e s2e
    Ultima modifica di anto999; 20-07-12 alle 21:24
    Il MODDING TI MODDA...NON INIZIARE
    by
    Gg636(il saggio )
    Ringraziato 84 volte in 70 Posts
    Quote Originariamente inviato da antonio8297 Visualizza il messaggio
    lo hai messo anche il comando datasd?
    no....perchè non ho capito cosa faccia di preciso...e non mi piace mettere cose che non capisco..a cosa serve??
    -è giusto che quando ho installato la adrenalin mi è uscita con schermata di spiegazione con scritto ace??
    -per installare la keybord della samsun va bene quella postata qui(Si può Mettere la tastiera Samsung con Cyanogenmod 7.1.0 ?) anche se è per Cm 7.1??
  4. #463
    Camposano (NA)
    Quote Originariamente inviato da sommo89 Visualizza il messaggio
    sposta tutti i dati su sd
    si,è giusto.
    si,si può mettere.
    by
    Gg636(il saggio )
  5. Il seguente Utente ha ringraziato anto999 per il post:
    sommo89 (20-07-12)
  6. #464
    si,è giusto.
    si,si può mettere.
    quali dati in più rispetto al primo comando??
    funziona bene o da problemi mettere quella tastiera?
  7. #465
    Camposano (NA)
    I dati delle app e li devi applicare tutti,io la ho e non ho mai avuto problemi
    Inviato dal mio GT-S5660 usando Androidiani App
    by
    Gg636(il saggio )
  8. #466
    Androidiano L'avatar di AlExFg90
    Foggia
    Samsung galaxy giò, lg nexus 4
    dalle impostazioni-cyanogenmod-interfaccia-e mi sembra modifica barra di stato(in inglese mi sembra che sia scritto)
    Ok perfetto, ho risolto. Era già presente l' orario solo che dovevo cambiare il colore per poterlo visualizzare sulla barra di stato. Grazie
  9. #467
    quindi dovrei ora come ora senza dover reinstallare a2sd devo andare nel terminare e fare
    su
    a2sd datasd
    e fa tutto lui in automatico giusto??
    se devo giocare a giochi particolarmente pesanti che governor consigliate??di default è su lilgV2
    Ultima modifica di sommo89; 20-07-12 alle 19:48
  10. #468
    Ringraziato 208 volte in 194 Posts
    io ti consiglio smartassv2.. anche con un massimo di 800 girano tranquillamente.. fruit ninja mi girava anche a 687
    Samsung Galaxy Gio White Pearl dead
    NOW Z3C green!!!
  11. #469
    Camposano (NA)
    su
    a2sd datasd
    fai
    su e dai invio
    a2sd zipalign e dai invio
    a2sd cachesdreset e dai invio,si riavvia all'accensione vai nel terminale e dai
    su e invio
    a2sd datasd e dai invio,si riavvia e avrai tutto nella sd-ext
    se la memoria si riempie vedi se si sono installate app sulla sd partizione fat
    by
    Gg636(il saggio )
  12. #470
    fai
    su e dai invio
    su e invio
    io fino al comando "cachesdreset" l'ho fatto non ho solo dato dal terminale datasd per un comando non dato devo rifare tutto??
    Quote Originariamente inviato da Massi91 Visualizza il messaggio
    mi dici un pò le caratteristiche di questo governor??domanda non si potrebbe creare una guida con tutti i governor con vantaggi/svantaggi e gli utilizzi??non ho questo governror...
    ho:
    -lazy
    -ondemandx
    -lagfree
    -SavagedZen
    -interactiveX
    -conservative
    -ondemand
    -powersave(intuitivo)
    -lilgV2(di default)
    -performance
    Ultima modifica di sommo89; 20-07-12 alle 21:39
