aquila989
Ragazzi, stavo gironzolando su XDA quando mi sono imbattuto in questo post :
[ROM] Enhanced236 - stock 2.3.6 - bug free - xda-developers
La tentazione è stata forte ed ho installato questa rom. E' fortissima, fatta davvero bene, mi piace tantissimo e credo proprio che la rimmarò installata.
Visto che mi è piaciuta moltissimo volevo condividerla con voi
Funziona anche a2sd!!!. Bella rom, davvero una bella rom.
DOWNLOAD [18.05.2012]:
enhanced236_18.05.2012.zip
Install instructions:
*Flash an ext4 supporting CWM
*Copy the zip file to the sd-card
*Use the "Install ZIP from sdcard" option in CWM to install it
*Wipe data & factory reset
Features:
l
*bug free
*all stock apps present, updated to latest versions
*Phiexz kernel 2.1 (ext3/ext4 support, swap support, prerooted, init.d support, BLN, custom bootanimation support etc.). More info on his website.
*ext4 format
*deodexed and zipaligned (+ zipalign on boot script)
*PDroid 1.31 patched (install app from Market)
*14 working toggles in notification panel (check screenshots) ***
*swype to remove notification (check screenshots)
*battery bar on statusbar (check screenshots) ***
*power menu modifications (check screenshots)
*native SIP client enabled
*camera sound follows system settings
*smooth scroll in applications
*unlimited contacts in SMS send to field
*sent time display for sms/mms after no network signal (instead of received time)
*no sms/mms in call logs
*sms converts to mms after 7 parts, not 4
*BLN working with stock SMS application
*enabled list view in app launcher
*minimal graphic modifications (CRT screen off animation, ICS animations, default smileys changed, some lockscreen text edits)
+ maybe a few more mods I forgot about
*** customise these features in Settings - ROM mods settings
*Disclaimer: This ROM has been tested extensively, but you use it on your own risk; I am not responsible and can't be held responsible for any problems or issues that may occur when flashing or using it.
*Credits and thanks: phiexz, hyriand, hansip87, dali47, untermensch, lidroid, pvyParts, svyat, montymintypie, AndroidON, jeboo, kohiiou
Changelog:
*changed filesystem to ext4;
*changed install method - cwm zip,
*changed kernel to Phiexz 2.1 (3.0 and later don't work on ext4)
*replaced Superuser with SuperSU
Gli screenshot potete visualizzarli nel post di xda
***[SE VI E' PIACIUTO IL MIO POST FATE CLICK SU THANKS, GRAZIE]***
