Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 11
[ROM] Enhanced236 - stock 2.3.6 - bug free[PRESO DAL FORUM XDA]
    Napoli
    galaxy gio, galaxy ace plus
    Ringraziato 86 volte in 26 Posts
    Ragazzi, stavo gironzolando su XDA quando mi sono imbattuto in questo post : [ROM] Enhanced236 - stock 2.3.6 - bug free - xda-developers
    La tentazione è stata forte ed ho installato questa rom. E' fortissima, fatta davvero bene, mi piace tantissimo e credo proprio che la rimmarò installata.
    Visto che mi è piaciuta moltissimo volevo condividerla con voi
    Funziona anche a2sd!!!. Bella rom, davvero una bella rom.
    DOWNLOAD [18.05.2012]:enhanced236_18.05.2012.zip
    Install instructions:
    *Flash an ext4 supporting CWM
    *Copy the zip file to the sd-card
    *Use the "Install ZIP from sdcard" option in CWM to install it
    *Wipe data & factory reset
    Features:
    *bug free
    *all stock apps present, updated to latest versions
    *Phiexz kernel 2.1 (ext3/ext4 support, swap support, prerooted, init.d support, BLN, custom bootanimation support etc.). More info on his website.
    *ext4 format
    *deodexed and zipaligned (+ zipalign on boot script)
    *PDroid 1.31 patched (install app from Market)
    *14 working toggles in notification panel (check screenshots) ***
    *swype to remove notification (check screenshots)
    *battery bar on statusbar (check screenshots) ***
    *power menu modifications (check screenshots)
    *native SIP client enabled
    *camera sound follows system settings
    *smooth scroll in applications
    *unlimited contacts in SMS send to field
    *sent time display for sms/mms after no network signal (instead of received time)
    *no sms/mms in call logs
    *sms converts to mms after 7 parts, not 4
    *BLN working with stock SMS application
    *enabled list view in app launcher
    *minimal graphic modifications (CRT screen off animation, ICS animations, default smileys changed, some lockscreen text edits)
    + maybe a few more mods I forgot about
    *** customise these features in Settings - ROM mods settings
    *Disclaimer: This ROM has been tested extensively, but you use it on your own risk; I am not responsible and can't be held responsible for any problems or issues that may occur when flashing or using it.
    *Credits and thanks: phiexz, hyriand, hansip87, dali47, untermensch, lidroid, pvyParts, svyat, montymintypie, AndroidON, jeboo, kohiiou
    Changelog:
    *changed filesystem to ext4;
    *changed install method - cwm zip,
    *changed kernel to Phiexz 2.1 (3.0 and later don't work on ext4)
    *replaced Superuser with SuperSU
    Gli screenshot potete visualizzarli nel post di xda [ROM] Enhanced236 - stock 2.3.6 - bug free - xda-developers
    ***[SE VI E' PIACIUTO IL MIO POST FATE CLICK SU THANKS, GRAZIE]***
  2. Il seguente Utente ha ringraziato aquila989 per il post:
    Henkone (29-05-12)
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    Quote Originariamente inviato da aquila989 Visualizza il messaggio
    Features:
    l
    *bug free
    *ext4 format
    Changelog:
    a voglio provare anche io!!!anche se ero interessato ad una custom rom 2.3.7
    E' di facile installazione?
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
  5. #3
    Napoli
    si è facile.
    [CONSIGLIATO]fai una seconda partizione in ext4(size 512, swap 0) da CMW
    copi la rom sulla sd
    la installi
    fai wipe data,factory reset e riavvia!
  6. #4
    Androidiani Power User L'avatar di anto999
    Camposano (NA)
    galaxy Nexus-galaxy gio
    Ringraziato 1,520 volte in 1,196 Posts
    si è facile.
    la installi
    I wipe si fanno prima dell'installazione!
    Inviato dalla mia friggitrice con Tapatalk 2
    Il MODDING TI MODDA...NON INIZIARE
    by
    Gg636(il saggio )
  7. #5
    Napoli
    Quote Originariamente inviato da antonio8297 Visualizza il messaggio
    io l'ho fatto dopo, cmq si, è meglio farlo anche prima
  8. #6
    Caserta
    LG P350,Sony Live With Walkman
    Ringraziato 254 volte in 212 Posts
    LG P350 (Pecan)
    Cyanogenmod 10.1
    Sony Ericsson Live With Walkman
    Rom:Cyanogenmod 10
    Kernel:Extended FXP Kernel
    OC:1607 MHz
  9. #7
    Napoli
    Quote Originariamente inviato da Frankin Visualizza il messaggio
    non l'avevo visto il tuo post, scusami
  10. #8
    Caserta
    Fa niente era scomparso
    LG P350 (Pecan)
    Cyanogenmod 10.1
    Rom:Cyanogenmod 10
    OC:1607 MHz
  11. #9
    Sep 2010
    ROMA
    dal tuo posto si evince che si flasha con odin..invece aquila parla di cwm...
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  12. #10
    Caserta
    Infatti se leggi su xda la rom è stata fatta sia in rfs(via odin ) sia in ext4 (cwm )
    LG P350 (Pecan)
    Cyanogenmod 10.1
    Rom:Cyanogenmod 10
    OC:1607 MHz
