Visualizzazione dei risultati da 1 a 10 su 44
CyanogenMod 9 | MoltenMotherBoard
    Androidiano VIP L'avatar di Samu636
    Pontinia (LT)
    Nexus 5x
    Ringraziato 362 volte in 273 Posts
    Crediti:
    • Jellaxy team
    • MoltenMotherBoard team!
    Screens:
    (Di screen ne arriveranno sicuramente altri dal mmb team.. in caso contrario provvedero ad aggiungerli)
    Downloads:
    GApps[B]
    Requisiti per il flash
    -Recovery ClockWorkMod 5.0.2.6 che se non avete già installata trovate QUI
    -Un Galaxy Gio*
    -Un cervello funzionante
    -Batteria carica almeno al 90%
    Installazione della rom:
    -Entrate in recovery(Tasto accensione + Tasto home)
    -Eseguite wipe data/factory reset
    -Eseguite wipe cache
    -Eseguite Advace--> Wipe dalvik cache*
    -Installare la rom facendo install zip from sd card->choose zip from sd card->e selezionate il file .zip della rom
    -Reboot(in caso di bootloop, andare di nuovo in recovery e fare i wipe)
    -Tornare in recovery
    -Andare in mounts & storage, selezionare muont system
    -Installare le GAPPS facendo install zip from sd card->choose zip from sd card-> e selezionate il file .zip delle GAPPS
    -Reboot and Enjoy*
    Changelog:
    -----RC-20130618 (? Downloads!):
    • Excluded Bluetooth Tether in Settings app (feature not properly working on GIO, hardware-level cause)
    • Excluded WiFi Direct in Settings app (feature not properly working on GIO, hardware-level cause)
    • Excluded CM Updates in Settings app (feature not needed and forcing closes)
    • USB and Wifi tethering fixed*
    • Gapps updated to 2013.06.14
    • Fixed Bluetooth issues (it didn't receive files, beacuse of missing prebuilt configurations files)
    • Improved S2E usage
    • Improved Camera effects
    • Included MMB banner
    • Hacked hosts file (no more Ads)
    • ADB icon hided
    • Fixed AudioFilter.csv (it made some audio lags)
    • Code updates from AOSP, CyanogenMod
    Changelog:
    -----RC-20130610 (212 Downloads!):
    • First release
    General Questions: MoltenMotherBoard Projects | General Questions and Info
    Official Mantainer(s): Mackief, ItachiSama, p4c0
    Link al thread di XDA: CyanogenMod 9 | MoltenMotherBoard XDA
    Fix vari al secondo post.
    Ultima modifica di Samu636; 21-06-13 alle 15:36
    Il modding ti modda non iniziare
    cit. Gg636
    "Nulla è reale, tutto è lecito quindi amo SuperSu" La dichiarazione di Astrone al sommo Supersu
  2. I seguenti 7 Utenti hanno ringraziato Samu636 per il post:
    Alex792 (07-10-13),Caribou (02-10-13),CriGio (11-06-13),Ghost_01 (24-06-13),giobeo (21-06-13),ivano949 (11-06-13),Mabit (12-06-13)
    Pontinia (LT)
    Nexus 5x
    Fix per il BLN creato da ivano949: http://db.tt/Ixm2WEQx
    Un thanks se lo merita
    Ultima modifica di Samu636; 15-06-13 alle 13:43
    cit. Gg636
  5. #3
    Pontinia (LT)
    Nexus 5x
    Riservato #2
    (grazie ivano per avermi ricordato dei post e della guida al flash.. oggi sto un po fuori )
    cit. Gg636
  6. #4
    LC
    vari ed eventuali
    Ringraziato 3,635 volte in 2,695 Posts
    Non va il link delle GApps, Samu
  7. Il seguente Utente ha ringraziato ivano949 per il post:
    Samu636 (11-06-13)
  8. #5
    Pontinia (LT)
    Nexus 5x
    Quote Originariamente inviato da ivano949 Visualizza il messaggio
    Aggiornato
    cit. Gg636
  9. #6
    Samsung Galaxy Gio (S5660)
    Bella Rom.
    Provata ed è bella fluida!
    Mi pare non supporti BLN!
  10. #7
    Pontinia (LT)
    Nexus 5x
    Quote Originariamente inviato da Solpic Visualizza il messaggio
    Bella Rom.
    Solpic, in caso tu abbia provato la aosp ics sempre del mmb team.. puoi far un confronto? Sempre se hai provato anche l altra rom
    cit. Gg636
  11. #8
    Si ho provato la aosp ics anche se non in maniera esauriente.
    Per un rapido confronto posso dirti che rispetto alla aosp ics,questa cyanogen ha parecchie personalizzazioni in più (graditissime almeno per me).
    Son presenti i vari toggle nel menù a tendina (cosa non presente nella aosp).
    Buona fluidità e mi pare che anche la camera funzioni bene.Fluida e non laggosa.
    Mi pare supporti Link2Sd.
    Piccolo neo la questione di BLN.A me interessava il funzionamento!
    Il launcher non lo apprezzo molto.Sono più abituato all'Holo e a tutte le sue chicche utili.
    In ogni caso devo dire che avevo sentito parlare molto male delle Cyano 9,ma avendo provata questa devo dire che invece son rimasto quasi del tutto soddisfatto!
    PS
    Un altra cosa.Se non mi ricordo male,all'interno della Cyano 9 manca un Gestore File.
    Personalmente lo ritengo una parte fondamentale!
    Ultima modifica di Solpic; 14-06-13 alle 11:50
  12. Il seguente Utente ha ringraziato Solpic per il post:
    Samu636 (13-06-13)
  13. #9
    LC
    vari ed eventuali
    Per il supporto a BLN ho creato una patch appositamente per voi....
    Scaricate il file e flashatelo usando la Cwm semplicemente facendo "install zip from sd card" riavviate e BLN dovrebbe funzionare
    Dico dovrebbe perché non avendo una scheda sim nel Gio non ho potuto testare però nella applicazione se prima dava errore ora si può abilitare
    Screenshot= http://db.tt/eAwhwcbM
    Fatemi sapere se funziona... Ma ovviamente credo di si
    FIRMA
  14. I seguenti 3 Utenti hanno ringraziato ivano949 per il post:
    giobeo (14-06-13),Samu636 (14-06-13),Solpic (14-06-13)
  15. #10
    Pontinia (LT)
    Nexus 5x
    Grazie mille ivano.. la testo appena flasho la rom (ne avevo 3 da flashare sta sera ) poi la metto nel primo post grazie
    cit. Gg636
