Credimi, veramente la migliore. Voglio provare ad installare la New WiFi module for i5700 to support SoftAP (WiFi tether for Froyo) di criminal, perchè il tethering sarbbe veramente utile. Vi faccio sapere.
CyanogenMod 6.1.1 Spica alpha8.1
ATTENZIONE: Il caricamento della MOD potrebbe danneggiare il vostro dispositivo! L'operazione di aggiornamento viene eseguita a Vs rischio e pericolo consapevoli che il dispositivo potrebbe incorrere in un cossidetto BRICK!
How to install
1. Download: CyanogenMod 6.1.1 Spica-alpha8.1
2. Put it to SD card
3. Enter to Recovery
4. Apply CM-6.1.1-Spica-a8.1_update.zip
5. Wipe data & cache!
6. Reboot (in the process of booting the phone may reboot a few (2-5) times, do not worry, wait)
7. Play
How to upgrade from earlier version of CyanogenMod
3. Just for sure: uninstall any Google Apps update
4. Enter to Recovery
5. Apply CM-6.1.1-Spica-a8.1_update.zip
7. Play
STATUS
+ Screen [LeshaK]
+ Touch/Multitouch [LeshaK/Gabriel-LG]
+ Audio [LeshaK/DE_NISkA/vflashbirdv]
+ Keys [Some keys doesn't works exactly same as Eclair]
+ GSM/GPRS/EDGE/3G [LeshaK]
+ Vibrate [LeshaK/Gabriel-LG]
+ SD Card [mik_os/LeshaK]
+ Wifi [golecpch]
+ Bluetooth [criminal]
+ Google services 20101020: (GMail/Market/Contacts/Calendar/NetworkLocationProvider)
+ GPS [criminal]
+ Sensors [DE-NISkA/Leshak/cadavre]
+ Camera [vflashbirdv/criminal]
+ Hardware accelerated movie playing/recording (mp4/h264) [vflashbirdv]
- Hardware accelerated movie playing (DivX)
CHANGELOG
alpha8.1:
1. Updated CyanogenMod sources to 6.1.1
2. Airplane mode vs Google Services fix [cujo]
3. Lock button fix [adi4motion]
4. Fix audio hardware continuous work even not playing any sound [vflashbirdv]
CHANGELOG (kernel)
New recovery: dynamic kernel parameters moved to /data/misc/xmister
Known issues/bugs
* Adobe Flash 10 (not Flash lite) does not work because it is not supported by the Spica.
* Accelerometer is a bit off and at times freeze screen in one orientation (usually horizontal), reboot resets.
* If system or data is on ext then there are some problems while booting and a clear dalvik or factory reset is required.
* Youtube does not work in HQ mode.
* Bluetooth looses connection with carkit
* USSD codes do not work if you update from previous alpha - require a factory reset for USSD codes to work
* SIP does not work
New :
CyanogenMod-6.1.1 (stable)
Airplane mode vs Google apps (ships with 8fix1) [cujo]
Spica Eclair style unlock [adi4motion]
1% battery xml at framework
I have removed bugs related to IMEI being zero after restart as it has not been reported for a long time now , so looks like the issue is fixed.If anyone finds this bug , please feel free to report it or better PM me so that it can be added again to the bug list. (munchy_cool)
Ultima modifica di ANDROIDPC; 17-12-10 alle 09:43
Smartphone: Samsung Galaxy NeXuS i9250
ROM: Stock JOP40D - JB 4.2.1 Rooted
Kernel: Stock 3.0.31
ma una domanda forse stupida....
io ho su la samdroid 2.2 e diciamo che mi va di provare anche questa Cyanogen....
per installarla che devo fa???
la installo mettendo lo zip nella sd e facendo la solita procedura o devo tornare alla 2.1 e poi installare questa???
e poi per tornare alla 2.1 devo necessariamente flashare con odin??
No, di norma, basta fare ogni volta un WIPE DATA/CACHE e poi caricare lo ZIP e puoi passare tranquillamente tra la SamdroidMOD 1.3 alla 2.2 alla CM 8.1.. ..è possibile però che fra i vari passaggi qualcosa vada storto e quindi sarà necessario rifare la procedura con ODIN.
Io sono sempre passato dalla Samdroid 1.3 alla CM e viceversa senza riflashare.. ..ma questo non significa che ci possa essere uno strappo alla regala..
ok allora mi sa che provo... giusto per vedere le differenze tra le due versioni...
ti dico... con la samdroid a parte rari impuntamenti va egregiamente... veloce il giusto e per ora nessun problema di imei reboot per l'accellerometro e via discorrendo!!!
la mia è sola pura curiosità!!
grazie dell'aiuto
sto installando
figo il logo mentre carica....
domani ti so dire...
Una ne sistemo ed una non va!!!!!!!!!!!!!!!!!!!
1)La cm 8.1 non mi si carica mi da aborted errore line XXX, ma poi la trovo come mod installata sul telefono
2)Il wifi tehter funziona ma se si vuole tornare all'uso semplice del wifi bisogna fare un reboot con data wipe
3) Utube non funziona, o meglio si sente ma non si vede.
ad essere sincero non ho provato... ;-)
