Pagina 2 di 6 primaprima 1234 ... ultimoultimo
Visualizzazione dei risultati da 11 a 20 su 53
[MOD 2.2] SamdroidMod 2.0.1 AOSP 8.5
  1. #11
    Super Droid L'avatar di ANDROIDPC
    Mar 2010
    Ringraziato 526 volte in 374 Posts
    Quote Originariamente inviato da mrzeus Visualizza il messaggio
    non mi salva gli apn!!! nooooo! è un bug risaputo?
    Penso proprio di no... :o
    Faresti bene a segnalarlo nell'apposita discussione su Samdroid..
    Smartphone: Samsung Galaxy NeXuS i9250
    ROM: Stock JOP40D - JB 4.2.1 Rooted
    Kernel: Stock 3.0.31
    Mar 2010
    Primi FIX di LeshaK
    camera works (bug with color),
    apps2sd works (thanks criminal)
    now working with ext2/4 support + last Xmister 'Ultimate Spica Recovery'
    ..si attende già la nuova release!!
  4. #13
    Mar 2010
    SamdroidMod 2.0.1 Alpha8.2 - Froyo [AOSP] for i5700
    ATTENZIONE: L'eventuale caricamento della MOD viene effettuato a vostro rischio e pericolo. Qualsiasi modifica al FW può arrecare danni irreparabili al Vs terminale
    Status (hardware)
    + GSM
    + GPRS/EDGE/3G
    + audio
    + wifi
    + bluetooth (thanks criminal)
    + sensors (thanks DE-NISkA)
    + GPS
    + multitouch (2.4, thanks Gabriel-LG)
    + SD/USB
    + Camera
    + ext2/4 support
    Status (software)
    + FileManager (from CyanogenMod)
    + Ultimate Spica Recovery (thanks Xmister)
    How to install
    1. Download (with Google Services): SamdroidMod 2.0.1 Alpha8.2
    2. Put it to SD card
    3. Enter to Recovery
    4. Apply SamdroidMod-2.0.1-Alpha8.2.zip
    5. Wipe data & cache!
    6. Reboot
    7. Play
    CHANGELOG
    alpha 8.2 [11/08/2010]
    - super full language pack version
    - Gallery3D by Androbot
    - Ultimate Spica Recovery (thanks Xmister)
    - fixed Superuser+su
    - camera
    - ext2/4 support [/system - rfs/ext2, /data - rfs/ext2/4, /cache - rfs/ext2] (but bug in recovery for converting rfs <-> extX, don't use!)
    - apps2sd (froyo native)
    - battery 1%
    TODO / BUGS
    - Wifi tethering
    - No DivX support(for s3c6410)
    - Sensors are not accurate, needs to be checked and fixed.
    - Speed can be further optimized after we get all the hardware working perfectly
    Ultima modifica di ANDROIDPC; 08-11-10 alle 12:26
  5. #14
    Dec 2009
    roma
    One Plus, Tab4, G3 32 gb ....
    Ringraziato 173 volte in 162 Posts
    Quote Originariamente inviato da ANDROIDPC Visualizza il messaggio
    Primi FIX di LeshaK
    Ho appena messo su la nuova alpha 8 (venendo da cyanogen) e devo dire che come fluidità non mi sembrano ci siano grandi differenze (in ogni caso sono entrambe superiori sia alla eclair che alla frozen eclair).
    Sto avendo qualche problema a far passare le applicazioni su ext4, fermo restando che le ho dovute tutte reinstallare ed alcune tramite sdk (genie widget per esempio). Gli APN italiani continuano a sparire ed ogni tanto mi chiede passwd gmail per market. Come già saputo, anche se con diversi tentativi di importazione da altri thread, il tethering non funziona e non si può avere il flash player. La camera va bene anche a colori adesso ed il BT funziona senza inceppi. Nuovamente problemi con le suonerie ed ogni tanto si autoreboot.
    Passo e chiudo
  6. #15
    Mar 2010
    e nemmeno il tempo di parlare della Alpha8 che LeshaK rilascia la 8.1!!
    CHANGELOG
    alpha.8.1 [11/07/2010]
    - full language pack version
    Essendo che la differenza rispetto la 8 è solo il supporto a tutte le lingue, aggiorno il post stesso della 8.1!!
  7. #16
    Dec 2009
    roma
    CHANGELOG
    Che grande
  8. #17
    Mar 2010
    Quote Originariamente inviato da ZENIGAD Visualizza il messaggio
    Che grande
    Grazie del complimento..
    ..ma penso che ti stavi rivolgendo proprio a LeshaK!!
    ..è veramente tosto stò ragazzo!
  9. #18
    Dec 2009
    roma
    CHANGELOG
    Scusami per la domanda , ma tu le applicazioni dove le hai caricate? sul telefono?
  10. #19
    Mar 2010
    Ti spiego.. ..tempo addietro ho avuto qualche problema con APPS2sD in quanto ho notato (e non solo a me) che dopo un certo periodo le applicazioni andavano in chiusura forzata!
    Quindi per un periodo ho usato solo la memoria interna (tanto giochi non ne uso!!) mentre adesso uso APPS2SD (EXT2 da 512Mb su SD da 8GB classe 6) ma non sposto la Dalvik Cache che resta nella mem interna.
  11. #20
    Dec 2009
    roma
    Ok. grazie. In realtà avevo lo stesso problema anche io all'inizio e su un forum mi hanno detto che uno dei problemi per la chiusura forzata delle applicazioni dipendeva dal fatto che non spegnevo mai il telefono (ANCHE DI NOTTE) e che quindi avrei dovuto resettare la dalvik almeno una volta al dì. Devo dire che ora non mi da più problemi.
    Altro argomento al quale magari mi sai dare una risposta: ti è mai capitato di non trovare sul market un'applicazione anche se te la prendevi dal market via web con code? Nel mio caso sto uscendo pazzo per freqmess.apk con un risultato pressocchè vicino allo zero assoluto
    Ultima modifica di ZENIGAD; 07-11-10 alle 15:55
