Dopo aver messo su YoNiP V12 CFS 24bpp Quadrant mi dà 690
Speriamo che fra un pò non esploda
Promette bene la BETA2.. ..penso che ormai il rilascio sia imminente..
Major TODO's:
- SIM Toolkit & USSD in extended networks [major in next release]
- BT bugs and avrcp [major in next release]
- DivX
BETA2
* Android 2.2.2 (AOSP)
* big code clean-up (darth-llamah)
* Bluetooth discoverability configurable (CyanogenMod, nebkat)
* clock text color fixes (nebkat)
* CM FileManager enabled (cadavre)
* DownloadManager and Browser from Gingerbread (nebkat)
* Email policies fix for Exchange (cadavre)
* extended SMS/MMS writing area to 6 lines in portrait (cadavre)
* framework cleanups (nebkat)
X GenKiller task manager (cadavre)
X init of screen state switch script in framework's PowerManager (cadavre)
* kernel framebuffer fix (tom3q)
* modified build flags and scripts (CyanogenMod, LeshaK, guybrusht)
* power button disabled in lockscreen (cadavre)
* PowerWidget - more long-press options (cadavre)
* rotary answer for calls (nebkat)
* RTL for framework and webkit (Y6b, cadavre) [available as additional package]
* SGM logo/anim (samdroid.net community)
* SMParts cleanup (nebkat)
* SMS send to wrong recipient fix (cadavre)
* some build fixes (Piskor)
* status bar PowerWidget new options (nebkat)
* sync off for sqlite databases improves in speed (XDA, cadavre)
* xml importing from CM and SGM fixed (cadavre)
* lockscreen improvements: (CyanogenMod, nebkat)
- rotary lockscreen unlock drag down
- music addons
- battery % info
- tab vibration on/off
- mms/phone tab custom apps
* Android fixes: (submitted by Piskor)
- DNS fix for wifi
- Change default DNS server for Tethering
- Introduce a list of all the audio files
- Telephony: Fix radio state printing
- Telephony: Process MT SMS with MTI set to 3
- Fixing counting the number of days in call log screen
- Change in media scanner to set correct date
- frameworks/base/telephony: Release wakelock on RIL request send error
- Changing connect and response timeout
- Bluetooth OBEX timeout problem
- Avoid leaking sockets
- Launcher is missing anti-aliasing
- java.lang.RuntimeException:Unable to pause activity (com.android.settings.applications.StorageUse)
* NEEDS CHECKING:
X avoid unwanted orientation chages on activity launch (cadavre)
X ! fix for phone/contacts locking in memory (cadavre)
Smartphone: Samsung Galaxy NeXuS i9250
ROM: Stock JOP40D - JB 4.2.1 Rooted
Kernel: Stock 3.0.31
Ieri sera Cadavre ha rilasciato la versione BETA2 ma nella notte è stata tolta dallo stesso autore per fixare dei problemi non meglio evidenziati.
Appena sarà disponibile in download della nuova versione provvederò ad aprire un apposita discussione!
Se avete scaricato da Samdroid la versione di ieri sera vi invito a NON caricarla per non incorrere a problemi visto che non sono stati indicati nemmeno i motivi per cui la ROM è stata levata dal download!
Poldone79 (10-04-11)
PRIMO!!!!
Il link è online su Samdroid... ADDOSSO!!!!
Tanto lo avevate già capito che non sono tanto a posto!
Galaxy Next Limegreen - Nobrand
Versione Android: 2.3.3
Versione Banda Base: S5570XXKPF
Versione Kernel: 2.6.35.7-perf-CL189639
Numero Build: GINGERBREAD.XXKPF
Ricordate: ANDROIDPC ha sempre ragione! anche se Voi forse non sapete chi è... sigh!!
