Utente del giorno: DreamReaper con ben 10 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: DreamReaper con ben 56 Thanks ricevuti negli ultimi sette giorni
Utente del mese: DreamReaper con ben 167 Thanks ricevuti nell'ultimo mese
Pagina 14 di 15 primaprima ... 412131415 ultimoultimo
Visualizzazione dei risultati da 131 a 140 su 141
YoNiP KerNeL .29 e .32
  1. #131
    Androidiano L'avatar di cic1
    Jan 2011
    OnePlus One
    Quote Originariamente inviato da ANDROIDPC Visualizza il messaggio
    Se la batteria drena troppo meglio tenersi il buon 12B1...
    Confermo ... son tornato alla V12B1! Senza dubbio la migliore per lo SPICA ...
    OPO 64Gb
    [Rom]CYANOGENMOD12- Nightly
    Jun 2010
    Altri aggiornamenti, sto per flashare la #48
    2.6.32.9
    Note: Be sure that your FS is all EXT2, if not Convert All File System to EXT2
    Apply at your own risk. Im not responsible if you brick your SPICA.
    ***WIPE DALVIK-CACHE and execute FIX PERMISSION in RECOVERY after installation***
    YONIP Final-3D Rev.02 VB#48 (151mb RAM) 3D mem optimized :
    YONIP Final-3D Rev.02 16Bpp (2.6.32.9) banjo-virtualbox #48 Multiupload.com - upload your files to multiple file hosting sites!
    YONIP Final-3D Rev.02 24Bpp (2.6.32.9) banjo-virtualbox #48 Multiupload.com - upload your files to multiple file hosting sites!
    YONIP Final Rev.02 VB#49 (Default Free RAM):
    YONIP Final Rev.02 16Bpp (2.6.32.9) banjo-virtualbox #49 Multiupload.com - upload your files to multiple file hosting sites!
    YONIP Final Rev.02 24Bpp (2.6.32.9) banjo-virtualbox #49 Multiupload.com - upload your files to multiple file hosting sites!
    CHANGELOG 2.6.32.9 Yonip Final Rev.01 VB#48 & VB#49:
    +Fix SD Mount Issue
    +Fix Freeze on Heavy Data usage on 3G (needs testing)
    +Fast & Stable
    +Compcache(0.6.2)/Swap Support
    +2D/3D Memory Optimization (Tested with full textures on latest angry birds and angry birds rio from market) *for VB#48 only*
    + Live Wallpaper Support (some users like LIVE WALLPAPER so use it your own will, *i don't recommend it* some games/apps may load slow if live wallpaper is enabled...)
  4. Il seguente Utente ha ringraziato kbkang per il post:
    cic1 (22-09-11)
  5. #133
    Super Droid L'avatar di ANDROIDPC
    Mar 2010
    Ringraziato 526 volte in 374 Posts
    Ciao Kbkang,
    si mi ero accorto delle ulteriori modifiche..
    ..ed adesso sono state pubblicate le versioni #50 e #51
    Appena posso aggiorno la prima pagina, per˛ per i test effettuati in precedenza questi Kernel .32 assorbono molta batteria senza conferire reali miglioramenti!
    Insomma.. ..l'hardware Ŕ quello e secondo me miracoli non se ne possono fare..
    Smartphone: Samsung Galaxy NeXuS i9250
    ROM: Stock JOP40D - JB 4.2.1 Rooted
    Kernel: Stock 3.0.31
  6. #134
    Mar 2010
    [AGGIORNAMENTO Kernel .32 #50 e #51]
    Riportati ovviamente in prima pagina
    CHANGELOG 2.6.32.9 Yonip Final Rev.01 VB#50 & VB#51:
    + Minor LowMemoryKiller adjustments
    + Remove some built-in tweaks that causes incompatibility with other MODS
    + Fix SD Mount Issue
    + Fix Freeze on Heavy Data usage on 3G (needs testing)
    + Fast & Stable
    + Compcache(0.6.2)/Swap Support
    + 2D/3D Memory Optimization (Tested with full textures on latest angry birds and angry birds rio from market) *for VB#50 only*
  7. #135
    Mar 2010
    [AGGIORNAMENTO Kernel .32 #52 e #53]
    CHANGELOG 2.6.32.9 Yonip Final Rev.01 VB#52 & VB#53:
    + Default LowMemoryKiller values
    + Reworked VM values
    + Stable
  8. #136
    May 2010
    Ho provato questi ultimi kernel, ma son dovuto tornare al 12 in quanto con l'hotspot attivo mi si riavviava il telefono ... :o
    Succede anche a voi?
  9. #137
    Mar 2010
    Quote Originariamente inviato da Kamaar Visualizza il messaggio
    Io non saprei perchŔ non li ho testati.. ..ma se vedi, nelle varie discussioni, ho SEMPRE consigliato il V12B!
  10. #138
    Jun 2010
    confermo i riavvii con i kernel 32, con quelli 29 non li rilevo. c'Ŕ da dire che con il kernel .29 il cellulare mi cade pi¨ spesso dalle mani
  11. #139
    Mar 2010
    Quote Originariamente inviato da kbkang Visualizza il messaggio
    ..Ŕ un BUG tremendo! Usa come FIX una bella custodia in silicone!
  12. #140
    Senior Droid L'avatar di shade66
    Oct 2010
    LocalitÓ
    Umbria
    LG OPTIMUS G
    mannaggia Ó lý bug der kernell...
    mi sta venendo in mente la malaugurata idea di passare alla SGM con buona pace dei video.
    ma vedo che Ŕ tutto un gran rappezzamento tra patch, kernel, fix! uŔ non che capisca, lavoro in una swhouse,
    ma Ŕ che il telefono lo uso... e farci beta (gamma?) testing mi terrorizza! :o
    scherzi a parte, tra SGM Beta3 e CM 6.1.1-Alpha 8.4, modifiche Yonip di questo post a parte (che devo ancora digerire!), quale mi si consiglia come stabilitÓ, velocitÓ (leggasi che non si 'impunti' come spesso fa la rom che attualmente monto in firma ), profonditÓ colore e capacitÓ di utilizzare il gps come navigatore outdoor (mi diletto a passeggiare in montagna e il gps mi Ŕ pi¨ necessario -quasi- del modulo telefonico) ?
    Ultima modifica di shade66; 15-10-11 alle 11:07
    Pensare senza fare Ŕ inutile, ma fare senza pensare Ŕ pericoloso! Diffidate di chi ve lo consiglia!
