Ma infatti ragazzi, voi siete mitici in quello che state facendo e dovrebbero farvi una statua d'oro ad entrambi, sia a te che a te che a giugra!
Inviato dal mio GT-I9205 usando Androidiani App
Ultima modifica di cincinnati; 28-01-15 alle 13:10
Hello
i have problems to install this rom 240 dpi
i can install just only the 320dpi
and than just only without wifi.
i want to install the 240 dpi with wifi ineed help or some tips
thank you for help
♢Wi-Fi -> how fix :
with some device have this bug wi fi. but this bug and rare but if there are problems follow the guidance indicated
✍1 Download stock rom samsung
http://www.sammobile.com/firmwares/d...VDNE1_ITV.zip/
flash them with odin.. open ecc config..
✍2 copy on sd card s5 Sway Rom
✍3 flash again ur phone with philtouch
https://goo.im/devs/philz_touch/CWM_...ltexx.tar.md5/
✍4 flash with odin modem
http://www21.zippyshare.com/v/xh1MVVzO/file.html
✍5 go in recovery
✍6 make wipe data and cache
✍7 install zip Sway Rom
✍8wait some minutes and succes!!
thank you for your help
have you a idea why i can not install the 240dpi verion
I wait the version with bluetooth correctif but you do a great job
djraz93 (28-01-15)
yes i know that, I want say where I can find to download, or what I do with apk ?
Thank you
