2012-10-02 09:11:57: Switch2SD started
2012-10-02 09:11:58: SD FAT partition is /dev/block/mmcblk0p1
2012-10-02 09:11:58: /sd-ext created
2012-10-02 09:11:58: Using partition /dev/block/mmcblk0p2
2012-10-02 09:11:58: ERROR: /sd-ext isn't mounted. Exiting...
2012-10-02 11:36:36: Switch2SD started
2012-10-02 09:36:37: SD FAT partition is /dev/block/mmcblk0p1
2012-10-02 09:36:37: /sd-ext created
2012-10-02 09:36:37: Using partition /dev/block/mmcblk0p2
2012-10-02 09:36:37: ERROR: /sd-ext isn't mounted. Exiting...
2012-10-02 11:46:21: Switch2SD started
2012-10-02 09:46:22: SD FAT partition is /dev/block/mmcblk0p1
2012-10-02 09:46:22: /sd-ext created
2012-10-02 09:46:22: Using partition /dev/block/mmcblk0p2
2012-10-02 09:46:22: ERROR: /sd-ext isn't mounted. Exiting...
