I know, "keep the same filename while extracting" you are right
name of firmware must be MODELPDA_CSC_MODEM > S5570I(MODEL)DDLG2(PDA)_[S5570i]ODDLG2(CSC)_S5570IDDLG2(MODEM)
thank you all
thank you all
Originariamente inviato da Fahmi1597
I used the same filename extracted from the sammobile archive. Just try with their source, all my firmwares didn't encounter any problems or errors.
Inviato dal mio GT-S5570I usando Androidiani App
