Originariamente inviato da Michelasso
Yep, michel.. the developer of px-kernel try to fix cwm 5.0.2.8 but if other one has fixed the another bugs will come ..
Sent from My Galaxy Mini Plus with JPlus 2.0 via Androidiani App
@fahmi: nice rom, I'm trying it right now, but as always I have some questions :):
1) Under settings -> quickpanel settings, tap on it and it FC, is it normal?
2) Black characters on grey background make reading some options very annoying, can you change it?
3) Your rom comes with stock kernel and you provide a link to cor plenus 2, is it the right 2.02 or just the plain 2.0? It's not the same :). Also, if you wish to link cor optimi 1.0 or the latest plenus, you can check my repository. Almost all the files have the source thread attached.
Regards :)
Edit: there's also an invalid ota entry.
Allegato 32042
Edit #2: it seems that the play store and youtube apps are not signed well to allow updates because I always get errors...
Fahmi, maybe I can help. If you do a batch signing of apps, maybe you did it wrong. I remind you that Gapps must have the original signature to allow updates, so you must leave them from the batch signature.
Korgar, the ota error shown occures when there isn't any rom update registered on the server.
Cribbio, almeno a me rispondi in italiano rotfl
Per ora ho rimesso la optimus.
adesso rimetto anche io la optimus ;)
Ragazzi qual'č il codice per l'italia?
Originariamente inviato da JL93
Boh? Io ho messo la rom, flashato il plenus e l'apn pare sia giusto. Non ho inserito nessun codice csc.
Inviato dal mio GT-S5570I usando Androidiani App
Io avendo visto l'avviso pensavo che fosse necessario. Comunque l'italiano c'č perņ lascia molte parti della rom non tradotte e poi ho notato che se voglio scrivere con la tastiera 3x4 e il T9 non posso impostare come lingua di inserimento l'italiano .-.
