Test things before uploading
I say nothing more
I say nothing more
Originariamente inviato da MagoPajas2
if i'm not test.. i'll not have.screen shot like in the first page.. and all of member galaxy next turbo in my country is no one have problem..
and i want see how better you are about create a rom
Sent from My Galaxy Mini Plus with JPlus 2.0 via Androidiani App
Really?
Status 6 usually means you edited your updater-script with a non-Unix-compatible text editor. Don't use Notepad or MS-Word!! You must use something like gVim or Notepad++. The other reason for this error may be that there is a syntax error in your updater-script.
I talk about Flash Update1
I do not mean the rom
I will try all the packages and see if it does the same for me.
Btw have you done a simple archive test to see if it's corrupted?
Inviato dal mio GT-S5570I usando Androidiani App
I solved your mistakes
Add this link to main post
I send link by mp
okay sorry, maybe my archive is corrupt or i forget to editing updater script
black background and black letters
plis can fix that
After school i will fix it
ok, thanks.
Nice rom !
