Utente del giorno: complicazio con ben 5 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: Stahl con ben 43 Thanks ricevuti negli ultimi sette giorni
Utente del mese: Stahl con ben 206 Thanks ricevuti nell'ultimo mese
Pagina 24 di 54 primaprima ... 14222324252634 ... ultimoultimo
Visualizzazione dei risultati da 231 a 240 su 540
[ROM] Nemesis One
  1. #231
    Senior Droid L'avatar di oscarnick93
    Torino
    Samsung Galaxy S Advance
    Ringraziato 87 volte in 66 Posts
    - Nuovo Update -
    ChangeLog -
    • All Features of NEMESIS HD
    • Faster+Stable(just try it!)
    • New Kernel!
    • Light Weight Bootanimation!!
    • New Status Bar
    • Removed Heavy Apps like Speak,Launcher,etc!![WILL ADD ZIPS FOR THEM SOON!]
    • Quickpic as Gallery
    • Pre-Installed Link2SD and CF3D!!!
    • rest for you guys to check out............................................... .........................
    ​Download
    • UPDATES-
    INSTRUCTIONS-
    • Get to Stock ROM and Kernel
    • Root the stock ROM[not necessary but still no harm in doing..........]
    • Go to CWM-by-madteam [http://www.mediafire...9835kooe7r2mtnf]
    • Wipe Data......................Cache................... .Dalvik Cache(Under Advanced)
    • Mount System[IT SHOULD SHOW "UNMOUNT"]
    • FLASH THE ROM ZIP
    • aroma will come.................just install the rom    [NOTHING ELSE]
    • Reboot
    • Wait as it is bound to take time!!!!!!
    If Boots Sucessfully Continue below!!!........................................
    • Now as you have the rom running time for the perfect kernel......RGHT?
    • Go to the Link below----
    • http://forum.xda-dev...d.php?t=1761166
    • DOWNLOAD THIS        savieSGY#73REV-by ronnieryan
    • Flash it from CWM after mounting System [FOLLOW INSTRUCTIONS ON PAGE!!!!    ]
    • AFTER FLASHING THE KERNEL REBOOT
    • IT TAKES MUCH TIME TO START WITH THIS KERNEL BUT END RESULT IS MUCH SMOOTHER ROM
    • If you Do not Like then use HELLS FUSION #50 latest one!!!![good kernel]
    • Now use the Phone with the Same CPU Config as Default [U CAN ALSO CHANGE THEM !!!!]
    - Per info andare cliccare sul link qui sotto, da quanto ho capito però si può scaricare solo tramite ota...
    [ROM][UPDATE 3/2/2013]NEMESIS PHOENIX[KERNEL] - Nemesis ROMs(Based on Stock Firmware) - Nemesis One Development Forum
    Ultima modifica di oscarnick93; 03-03-13 alle 13:36
    ..:: Samsung Galaxy S II I9100 No Brand-Black ::..
    ..:: Rom: Resurection Remix LP 5.5.3 ::..
    ..:: Kernel: 3.0.64-CM-g7e7a10d ::..
  2. Il seguente Utente ha ringraziato oscarnick93 per il post:
    TheDarkDragon (03-03-13)
    Androidiano L'avatar di eduenache
    Ringraziato 42 volte in 20 Posts
    Omg scarico subito da ota!
    Eh però dice new kernel...Dovremo riflashare il cyanus e fix?Oscar tu l'hai provata?
    Terminale: Samsung Galaxy Next Turbo
    Kernel: Plenus 2.1.7
    Tema: Ics/Jb Style per rom stock (3.0) By IronAndy e Skillvester (eduenache)
  5. #233
    Torino
    Quote Originariamente inviato da eduenache Visualizza il messaggio
    dimmi poi com' è che io non possiedo questa rom ma credo sia spettacolare l'avevo provata ma poi tolta :/... io ho fornito solo l'aggiornamento in quanto aspetto una versione definitiva... poi non so le procedure le ho postate però si bisogna partire da stock room con i permessi di root e poi fare i vari wipe e flashare il kernel . tutto scritto sopra nelle istruzioni in inglese XD
    Ultima modifica di oscarnick93; 03-03-13 alle 13:38
  6. #234
    Eh ora non ricordo come si entra nell'OTA updater e comunque ho paura che mi briccki il telefono il kernel..Poi dovrò rifare tutto ecc,preferisco lasciarla così che va bene,aspettiamo il port!
  7. #235
    Androidiano VIP L'avatar di Jeeko
    Galaxy S2 Plus
    Ringraziato 492 volte in 239 Posts
    La provo io tra poco
    EDIT: funziona, flashando il Cyanus 1.5 ed i fix... però non funziona il bluetooth ed il wifi, inoltre questa NEMESIS PHONEIX è basata su ICS che non mi piace molto
    Ultima modifica di Jeeko; 03-03-13 alle 14:42
    Samsung Galaxy S2 I9105P - Developer - PureSeries™Admin
    Now Browser, the lightest browser on the market (160kb)
  8. #236
    Galaxy W - Mediacom 910i
    Quote Originariamente inviato da Jeeko Visualizza il messaggio
    Ma hai installato anche i fix?
    Si subito dopo aver installato la rom, proprio come nella video guida.
    Apprate due force close quando si accende il dispositivo non ho trovato nessun bug, quindi consiglio questa rom a tutti i possessori del next turbo!!!
  9. #237
    Androidiano VIP L'avatar di androidianoBOSS
    AL MOMENTO NIENTE
    Ringraziato 299 volte in 261 Posts
    si anche a me piace tanto la consiglio anche io..!
    DEVICE:Galaxy next turbo
    ROM:Stock NO-BRAND
    KERNEL:Stock
    SE TI SONO STATO UTILE CLICCA THANKS IN BASSO A SINISTRA
  10. #238
    Androidiano VIP L'avatar di Miky500
    Foggia, FG, Italy
    I9070-S5570I
    Ringraziato 227 volte in 195 Posts
    Ragazzi come risolviamo il GPlay Services?
    Inviato dal mio GT-S5570I con Tapatalk 2
    My devices:
    LG G3 - Stock 5.0
    Galaxy Note 3 Neo - Stock 4.4.2 (display rotto )
    Galaxy S Advance - Stock 4.1.2 + CoCore 8.2
    Galaxy Next Turbo - Stock 2.3.6 + root
    P.S. Usate il tasto thanks, non fa del male.
  11. Il seguente Utente ha ringraziato Miky500 per il post:
    devilyuri (05-03-13)
  12. #239
    AL MOMENTO NIENTE
    me lo stavo chiedendo anche io...speriamo presto..!
    ROM:Stock NO-BRAND
    KERNEL:Stock
  13. #240
    Androidiano VIP L'avatar di gius01
    Napoli
    Huawei Ascend G510
    Ringraziato 165 volte in 147 Posts
    Quote Originariamente inviato da androidianoBOSS Visualizza il messaggio
    Anche con un apk preso da un tablet Audiola/Majestic(sembrano marche di prestigio e poi scopri che hanno integrato binario su e busybox.. fine OT) non va
    Inviato dal mio GT-S5360 con Tapatalk 2
    Usate il forum per aiuto! Non rispondo a PM di aiuto
    Un thanks non costa un mutuo quindi schiaccialo se sono stato utile. Vedi in basso a sinistra
