codice:
I: Smaling...
I: Checking whether resources has changed...
I: Building resources...
C:\Users\Alessio.Alessio-PC\Desktop\APK-Multi-Tool\other\..\projects\Phone.apk\
es\values-de\strings.xml:208: error: Multiple substitutions specified in non-po
itional format; did you mean to add the formatted="false" attribute?
es\values-de\strings.xml:209: error: Unexpected end tag string
es\values-es\strings.xml:216: error: Multiple substitutions specified in non-po
es\values-es\strings.xml:217: error: Unexpected end tag string
es\values-es-rUS\strings.xml:173: error: Multiple substitutions specified in no
-positional format; did you mean to add the formatted="false" attribute?
es\values-es-rUS\strings.xml:174: error: Unexpected end tag string
es\values-it\strings.xml:219: error: Multiple substitutions specified in non-po
es\values-it\strings.xml:220: error: Unexpected end tag string
Exception in thread "main" brut.androlib.AndrolibException: brut.androlib.Andro
ibException: brut.common.BrutException: could not exec command: [aapt, p, --min
sdk-version, 17, --target-sdk-version, 17, -F, C:\Users\ALESSI~1.ALE\AppData\Lo
al\Temp\APKTOOL8365207088700794156.tmp, -0, arsc, -I, C:\Users\Alessio.Alessio-
C\apktool\framework\1.apk, -S, C:\Users\Alessio.Alessio-PC\Desktop\APK-Multi-To
l\other\..\projects\Phone.apk\res, -M, C:\Users\Alessio.Alessio-PC\Desktop\APK-
ulti-Tool\other\..\projects\Phone.apk\AndroidManifest.xml]
at brut.androlib.Androlib.buildResourcesFull(Androlib.java:358)
at brut.androlib.Androlib.buildResources(Androlib.java:283)
at brut.androlib.Androlib.build(Androlib.java:206)
at brut.androlib.Androlib.build(Androlib.java:176)
at brut.apktool.Main.cmdBuild(Main.java:228)
at brut.apktool.Main.main(Main.java:79)
Caused by: brut.androlib.AndrolibException: brut.common.BrutException: could no
exec command: [aapt, p, --min-sdk-version, 17, --target-sdk-version, 17, -F, C
\Users\ALESSI~1.ALE\AppData\Local\Temp\APKTOOL8365207088700794156.tmp, -0, arsc
-I, C:\Users\Alessio.Alessio-PC\apktool\framework\1.apk, -S, C:\Users\Alessio.
lessio-PC\Desktop\APK-Multi-Tool\other\..\projects\Phone.apk\res, -M, C:\Users\
lessio.Alessio-PC\Desktop\APK-Multi-Tool\other\..\projects\Phone.apk\AndroidMan
fest.xml]
at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.ja
a:357)
at brut.androlib.Androlib.buildResourcesFull(Androlib.java:336)
... 5 more
Caused by: brut.common.BrutException: could not exec command: [aapt, p, --min-s
k-version, 17, --target-sdk-version, 17, -F, C:\Users\ALESSI~1.ALE\AppData\Loca
\Temp\APKTOOL8365207088700794156.tmp, -0, arsc, -I, C:\Users\Alessio.Alessio-PC
apktool\framework\1.apk, -S, C:\Users\Alessio.Alessio-PC\Desktop\APK-Multi-Tool
other\..\projects\Phone.apk\res, -M, C:\Users\Alessio.Alessio-PC\Desktop\APK-Mu
at brut.util.OS.exec(OS.java:89)
a:355)
... 6 more
Ma voi riuscite con il PHONE della CM10.1?
