codice:
[ 01-05 22:17:09.659 108: 712 E/QualcommCameraHardware ]
native_set_parm: error (No such file or directory): fd 27, type 12, length 4, status 0
[ 01-05 22:17:09.659 108: 1410 E/mm-camera ]
LENS ROLLOFF not supported on this SENSOR!!!
[ 01-05 22:17:09.669 520: 586 I/ActivityManager ]
Resuming delayed broadcast
[ 01-05 22:17:09.709 108: 712 E/QualcommCameraHardware ]
native_set_parm: error (No such file or directory): fd 27, type 37, length 1, status 0
native_set_parm: error (No such file or directory): fd 27, type 11, length 4, status 0
[ 01-05 22:17:09.709 108: 712 D/QualcommCameraHardware ]
createInstance: X created hardware=0x22288
[ 01-05 22:17:09.709 108: 712 D/QcomCamera ]
camera_device_open:--
[ 01-05 22:17:09.739 1372: 1391 V/CameraManager ]
Camera is open
[ 01-05 22:17:09.819 1372: 1391 D/CameraManager ]
preferred-preview-size-for-video=320x240;sharpness-max=4;zoom=0;zoom-supported=true;metering=frame-average;sharpness=2;contrast=2;whitebalance=auto;jpeg-quality=85;preview-format-values=yuv420sp;jpeg-thumbnail-quality=90;preview-format=yuv420sp;video-size-values=1280x720,800x480,720x480,640x480,352x288,320x240,176x144;preview-size=320x240;auto-exposure-values=frame-average,center-weighted,spot-metering;iso=auto;flash-mode-values=off,auto,on,torch;preview-frame-rate-values=10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25;preview-frame-rate=15;focus-mode-values=;jpeg-thumbnail-width=512;video-size=320x240;preview-fps-range-values=(15,30);zoom-ratios=100,105,110,115,120,125,130,135,140,145,150,155,160,165,170,175,180,185,190,195,200,205,210,215,220,225,230,235,240,245,250,255,260,265,270,275,280,285,290,295,300;saturation-def=2;preview-size-values=800x480,768x432,640x480,576x432,480x320,384x288,352x288,320x240,240x160,176x144;picture-size-values=2048x1536,1600x1200,1280x768,1280x720,1024x768,800x480,640x480,352x288,320x240,176x144;min-exposure-compensation=-2;antibanding=off;contrast-max=4;vertical-view-angle=39.4;luma-adaptation=3;contrast-def=2;horizontal-view-angle=51.2;jpeg-thumbnail-height=384;focus-mode=auto;sharpness-def=2;video-frame-format=yuv420sp;picture-format-values=jpeg,raw;saturation-max=4;max-exposure-compensation=4;exposure-compensation=1;exposure-compensation-step=1;flash-mode=off;effect-values=none,mono,negative,sepia;picture-size=1024x768;max-zoom=39;effect=none;saturation=2;whitebalance-values=auto,daylight,cloudy-daylight,fluorescent,incandescent;picture-format=jpeg;lensshade-values=enable,disable;iso-values=auto,ISO100,ISO200,ISO400;lensshade=enable;antibanding-values=off,50hz,60hz,auto
[ 01-05 22:17:09.879 108: 108 E/QualcommCameraHardware ]
native_set_parm: error (Success): fd 27, type 12, length 4, status 0
[ 01-05 22:17:09.879 108: 1410 E/mm-camera ]
[ 01-05 22:17:09.929 108: 108 E/QualcommCameraHardware ]
native_set_parm: error (Success): fd 27, type 37, length 1, status 0
native_set_parm: error (Success): fd 27, type 11, length 4, status 0
[ 01-05 22:17:09.939 1372: 1391 D/Camera ]
app passed NULL surface
[ 01-05 22:17:09.949 1372: 1380 W/CursorWrapperInner ]
Cursor finalized without prior close()
[ 01-05 22:17:09.999 108: 304 I/AudioHardwareMSM72XX ]
disabling post proc features with mask 0x0000
[ 01-05 22:17:10.349 1310: 1310 W/IInputConnectionWrapper ]
showStatusIcon on inactive InputConnection
[ 01-05 22:17:10.349 1372: 1372 I/Choreographer ]
Skipped 131 frames! The application may be doing too much work on its main thread.
[ 01-05 22:17:10.579 1372: 1372 E/Camera-JNI ]
Null byte array!
[ 01-05 22:17:10.579 1372: 1372 V/CameraManager ]
Preview size is 320x240
[ 01-05 22:17:10.579 108: 712 I/CameraClient ]
stopPreview: Disable picture related messages
[ 01-05 22:17:10.589 108: 306 E/QualcommCameraHardware ]
[ 01-05 22:17:10.589 108: 1410 E/mm-camera ]
[ 01-05 22:17:10.639 108: 306 E/QualcommCameraHardware ]
[ 01-05 22:17:10.679 108: 108 D/QualcommCameraHardware ]
mBufferSize=115200, mAlignedBufferSize=118784
num_buffers = 4
[ 01-05 22:17:10.679 108: 1426 D/QualcommCameraHardware ]
frame_thread E
[ 01-05 22:17:10.839 108: 108 D/QualcommCameraHardware ]
ctrlCmd.value = 60
Maximum zoom value is 39
[ 01-05 22:17:10.869 1372: 1372 D/AndroidRuntime ]
Shutting down VM
[ 01-05 22:17:10.869 1372: 1372 W/dalvikvm ]
threadid=1: thread exiting with uncaught exception (group=0x4163fbc0)
[ 01-05 22:17:10.869 1372: 1372 E/AndroidRuntime ]
FATAL EXCEPTION: main
Process: org.cyanogenmod.focal, PID: 1372
java.lang.RuntimeException: enable focus move callback failed
at android.hardware.Camera.enableFocusMoveCallback(Native Method)
at android.hardware.Camera.setAutoFocusMoveCallback(Camera.java:1182)
at org.cyanogenmod.focal.CameraManager.setAutoFocusMoveCallback(CameraManager.java:807)
at org.cyanogenmod.focal.FocusManager.<init>(FocusManager.java:65)
at org.cyanogenmod.focal.CameraActivity$7.run(CameraActivity.java:657)
at android.os.Handler.handleCallback(Handler.java:733)
at android.os.Handler.dispatchMessage(Handler.java:95)
at android.os.Looper.loop(Looper.java:136)
at android.app.ActivityThread.main(ActivityThread.java:5114)
at java.lang.reflect.Method.invokeNative(Native Method)
at java.lang.reflect.Method.invoke(Method.java:515)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:781)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:597)
at dalvik.system.NativeStart.main(Native Method)
[ 01-05 22:17:10.889 520: 744 W/ActivityManager ]
Force finishing activity org.cyanogenmod.focal/.CameraActivity
[ 01-05 22:17:10.909 108: 1426 W/CameraClient ]
lockIfMessageWanted(16): dropped unwanted message
[ 01-05 22:17:11.019 108: 1426 W/CameraClient ]
