XDA
Hello guys !! I have make an application to auto modify multiple apk for multiwindows with APK-Multi-Tool !
1 - Just put yours APKs in "place-apk-here-for-modding" folder
2 - Run APKMultiWindows.exe
3 - Then Click GO
4 - Wait and when it finish it open folder contains all modify APK !
WARNING : Your APK do not contains space or "(" ")" and maybe other special char.
note : For use this program you need to install java 1.6 minimum and after you need to create 2 environment variable.
PATH => C:\Program Files\Java\jdk1.6.0_18\bin
JAVA_HOME => C:\Program Files\Java\jdk1.6.0_18
Step 1 : Right Click on MyComputer and click on properties .
Step 2 : Click on Advanced tab
Step 3: Click on Environment Variables
Step 4: Create a new class path for JAVA_HOME
Step 5: Enter the Variable name as JAVA_HOME and the value to your jdk bin path ie C:\Program Files\Java\jdk1.6.0_18
Step 6: SAme for Path
Enjoy !!!
