Sneakykat 2.5 on line
Il mio C.V.
Tester:
- Audax rom
- FoxHounh team
- Blumark
- Abyss kernel
- R2D2 Droid
Editore per Batista70 phone
skyhigh 1,8 online
Il mio C.V.
Tester:
- Audax rom
- FoxHounh team
- Blumark
- Abyss kernel
- R2D2 Droid
dado72 (06-06-14)
Carlocira (07-06-14)
ah ma anche con la cyano snapshot m6 si perdono le funzioni della s pen ?
E stato rilasciato abyss 1.7.0
guidoiann (08-06-14),japoco_poz14 (08-06-14)
Sneakykat 2.6 On-line
08/06/2014 REV2.6 SneakyKat
Exteme and normal version are one now thanks to the new HardLimit CPU driver of Yank555.lu
New 2.0 Hardlimit driver
New Led driver 1.2 by Yank555.lu
With the new cpu driver the only good app to control this kernel is Synapse!
Reason for Synapse is that only this app controls the correct settings to control the new CPU driver.
Other apps like Trickster can control only the normal valeus like min_scaling_freq & max_scaling_freq.
This new kernel uses other kernel entries to override the samsung DVFS controlled settings.
So again thanks to Yank55.lu for this awsome driver to go past Samsung DVFS control and Andreilux for this supurb app that can control any setting that you want and add any setting that you want.
Il mio C.V.
Tester:
- Audax rom
- FoxHounh team
- Blumark
- Abyss kernel
- R2D2 Droid
dado72 (09-06-14)
Per avere il link?
