X conoscenza aggiornamento kernel skyhigh v 2.1
<-----Un grazie non costa niente premi Thanks
[QUOTE=japoco_poz14;5727683]Sneakykat 2.6 On-line
08/06/2014 REV2.6 SneakyKat
Exteme and normal version are one now thanks to the new HardLimit CPU driver of Yank555.lu
New 2.0 Hardlimit driver
New Led driver 1.2 by Yank555.lu
With the new cpu driver the only good app to control this kernel is Synapse!
Reason for Synapse is that only this app controls the correct settings to control the new CPU driver.
Other apps like Trickster can control only the normal valeus like min_scaling_freq & max_scaling_freq.
This new kernel uses other kernel entries to override the samsung DVFS controlled settings.
So again thanks to Yank55.lu for this awsome driver to go past Samsung DVFS control and Andreilux for this supurb app that can control any setting that you want and add any setting that you
Risolto io
http://www.androidfilehost.com/?fid=23501681358544542
Ultima modifica di marco7677; 09-06-14 alle 19:57
dado72 (10-06-14)
Bullproject (10-06-14)
Io monto per adesso il Lean kernel 2.6... ma vorrei provare qualche altro kernel.... quale kernel mi consigliate di provare??
mirkocon995 (10-06-14)
