Based on firmware XXDLJ2 Android 4.1.2 (Date: 29/10/2012)
Kernel XXDLJ2
Modem XXDLJ2
Multi CSC (118 csc): XXALJ1 set to EUR
Aroma installer
Installation is fully customizable by user and there is options to install everything and remove Bloatware
Read
here for more info.
With custom Installation you take control of what is installed in your device.
Full Wipe option in Aroma installer
Wipe cache partition automatic before roms installation
Wipe Dalvik Cache automatic during installation
Wipe preload partition automatic before roms installation
efs Backup option in Aroma installer
init.d support without the need of a kernel that supports init.d
Added:
Busybox
SuperSU
OmegaDroid wallpaper
OmegaDroid Walk Bootanimation
by Jorq1H
Omegadroid Bootanimation by
Jorq1H and
anbech Omegas artists!
GenieWidget
Live Wallpapers
Flashplayer support
Updated (to latest version):
Gmail
Google Maps
Play Store
Google Search
Mods:
Call Recorder
Phone with no increasing ringtone
All supported languages enabled
All supported languages for Samsung Keyboard enabled
Email with Exchange Security Disabled
Unlimited contacts can be added sms and no sms to mms conversion.
15 Toggle Buttons Mod
4 way reboot menu
Disable Scrolling Cache
TouchWiz with wallpaper scrolling
Battery % mod
Disabled advertisements
Faster GPS lock
Enable custom bootanimations
Enable init.d scripts
Contacts with Greek index
Shutter Sound menu Enabled to stock camera
Remove Blocking Mode Icon
APNs list from cm10
200 contacts can be added to mms app
Join more unlimited contacts in the contact app
Task Manager Note 2 Shortcut
by cb56
Tweaks:
build.prop tweaks
Stock Theme Changes:
Dithered Holo Background added by Zabalba
Blue % battery icons
Blue Toggle Buttons
Google apps from Android 4.2:
Playstore v3.9.17
Gmail v4.2
Camera and Gallery from Android 4.2
Keyboard Android with Gesture Typing from Android 4.2
Keyboard with Emoji Support from Android 4.2
Clock Application from Android 4.2
Omegas addon applications:
Es File Explorer (with great Root Explorer)
Hide It Pro
ZArchiver
Theme:
Black Status bar
Blue circle battery icons
Removed:
Boot sound
Charger Connection Sound
Shutdown Animation
Removed Bloatware:
Learning hub
Reading hub
ChocoEUKor.apk
DeepSea.apk
Rom is Deodexed + Rooted + Zipaligned
