Picciotto
Un abisso...................
Based on firmware XXDLJ2 Android 4.1.2 (Date: 29/10/2012)
Kernel XXDLK7
Modem XXDLK7
Multi CSC (118 csc): XXALJ1 set to EUR
Aroma installer
Installation is fully customizable by user and there is options to install everything and remove Bloatware
Read here for more info.
With custom Installation you take control of what is installed in your device.
Full Wipe option in Aroma installer
Wipe cache partition automatic before roms installation
Wipe Dalvik Cache automatic during installation
Wipe preload partition automatic before roms installation
efs Backup option in Aroma installer
init.d support without the need of a kernel that supports init.d
Added:
Busybox
SuperSU
OmegaDroid wallpaper
OmegaDroid Walk Bootanimation by Jorq1H
Omegadroid Bootanimation by Jorq1H and anbech Omegas artists!
GenieWidget
Live Wallpapers
Flashplayer support
Updated (to latest version):
Gmail
Google Maps
Play Store
Google Search
Mods:
Simplistic Framework by LegendK95
23 toggles mod with Toggles control app by LegendK95
Option to Change Number of Toggles in a row (5-6-7)
Option to set Scrolling wallpaper on-off by LegendK95
Option to Change %battery icons with stock battery icons at any time
Power Menu with Recovery and Download
InkEffect Lockscreen enabled with finger
Skip music tracks with volume buttons long press
Call Recorder
Phone with no increasing ringtone
All supported languages enabled
All supported languages for Samsung Keyboard enabled
Email with Exchange Security Disabled
Unlimited contacts can be added sms and no sms to mms conversion.
Disable Scrolling Cache
TouchWiz with wallpaper scrolling
Battery % mod
Disabled advertisements
Faster GPS lock
Enable custom bootanimations
Enable init.d scripts
Contacts with Greek index
Shutter Sound menu Enabled to stock camera
Remove Blocking Mode Icon
APNs list from cm10
Unlimited contacts can be added to sms - mms
No sms to mms conversion
Join more unlimited contacts in the contact app
Task Manager Note 2 Shortcut by cb56
Camera will switch off at 0% Battery
Silent camera
Call Delay After call End Reduced to 0ms
Enable sub Symbols on Stock Samsung keyboard
Dialer search matches numbers in contacts and call logs along with contacts
Added exit menu to stock web browser
Tweaks:
build.prop tweaks
Stock Theme Changes:
Dithered Holo Background added by Zabalba
Green % battery icons
Green Toggle Buttons
Google apps from Android 4.2:
Playstore v3.9.17
Gmail v4.2
Camera and Gallery from Android 4.2
Keyboard Android with Gesture Typing from Android 4.2
Keyboard with Emoji Support from Android 4.2
Clock Application from Android 4.2
Omegas addon applications:
Es File Explorer (with great Root Explorer)
Hide It Pro
ZArchiver
AddFree
MultiWindows Control by LegendK95
Simplistic Toggles Control app exclusive made for Omega with more features by LegendK95
Theme:
Black Status bar
Green circle battery icons
Removed:
Boot sound
Charger Connection Sound
Shutdown Animation
Removed Bloatware:
Learning hub
Reading hub
ChocoEUKor.apk
DeepSea.apk
Rom is Deodexed + Rooted + Zipaligned
