Nuovo kernel Perseus disponibile in ota, consiglio l'aggiornamento!
Perseus alpha24 (09/10):
Galaxy Note 2 source and kernel merge. Various platform fixes included from patching up from update5.
Fixed Mali GPU interface bugs relating to staycount, and lowered undervolt-soft limit down to 600mV.
Feature recap for new Note 2 users:
- Overclocking up to 1.8GHz and undervolting support through SetCPU. Note 2 users have a better quality CPU than Galaxy S3 users, so mind the default high voltages on those frequencies.
- GPU overclocking and undervolting support.
- A great amount of changes to improve battery life.
- Features which are in strikethrough in the changelog below do not work/are not ported on the Note 2, yet.
24.3 => Sharpness fix for the display included. Courtesy of hardcore.
24.4 => Removed Touch Boost in exchange for the Flexrate mechanisms. See below in changelog for more information.
Ported LCDFreq to the Note 2. See below in changelog for more information. The flickering is sadly still there on the Note 2.
Fixed undervolting below 850mV, previous undervolting below that value would be disregarded and 850mV would be applied in reality, even if it showed up the entered value.
Improved boot time by about 22 seconds: Fixed a major bug in the sensor hub firmware update logic, in the stock kernel and currently published sources the sensorhub firmware is being flashed over the current one on every boot, regardless if the payload firmware is the same as the current one. The update is about 130kB but it is done over the incredibly slow i2c bus, so this slowed down boot considerably. The reason was mis-labeling of the kernel firwmare version in the driver and failure to check if firmware was actually newer.
