Come kernel con quale vi trovate meglio?
Abyss non mi sembra male, il RedPill dovrebbe consumare troppo e il Perseus sta riprendendo campo.
Controllo..... Che dite di questi settings?
sent with my beast N2
Perchè gli Androidiani sono così restii a premere Thanks???????????
Nuovo script per Perseus v26 (il quale va a modificare, peggiorando la situazione, il cpu up rate e il cpu down rate)
#!/system/bin/sh
## Voltage Control boot script by xan and nitr8 ##
LOG_FILE=/data/volt_scheduler.log
rm -Rf $LOG_FILE
echo "Starting Insanity Volt Scheduler $( date +"%m-%d-%Y %H:%M:%S" )" | tee -a $LOG_FILE;
echo "Sleeping for 20 seconds to workaround oc not setting properly on stock derivatve roms..."
sleep 20
echo "Ok lets start working"
echo "Set MIN Scaling Frequency" | tee -a $LOG_FILE;
echo "200000" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
echo ""
echo "---------------"
echo "Set MAX Scaling Frequency" | tee -a $LOG_FILE;
echo "1704000" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
echo ""
echo "Set Scheduler for stl, bml and mmc" | tee -a $LOG_FILE;
for i in `ls /sys/block/stl*` /sys/block/bml* /sys/block/mmcblk* /sys/block/mtdblock* ; do
echo "sio" > $i/queue/scheduler;
echo "$i/queue/scheduler";
done;
echo "---------------";
echo "Set governor" | tee -a $LOG_FILE;
echo "pegasusq" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo "sio" > /sys/block/mmcblk0/queue/scheduler
echo ""
#UV_BEGIN#
echo "Set UV" | tee -a $LOG_FILE;
echo "1300 1225 1175 1150 1125 1100 1075 1050 1025 1000 975 950 925 900 875 850 825" > /sys/devices/system/cpu/cpu0/cpufreq/UV_mV_table
"GPU voltages " | tee -a $LOG_FILE;
echo "54 108 160 266 350 440 533 640 733 800" > /sys/devices/system/gpu/freq_table
echo 54 800 > /sys/devices/system/gpu/volt_table
echo 108 825 > /sys/devices/system/gpu/volt_table
echo 160 850 > /sys/devices/system/gpu/volt_table
echo 266 900 > /sys/devices/system/gpu/volt_table
echo 350 950 > /sys/devices/system/gpu/volt_table
echo 440 1000 > /sys/devices/system/gpu/volt_table
echo 533 1050 > /sys/devices/system/gpu/volt_table
echo 640 1100 > /sys/devices/system/gpu/volt_table
echo 733 1150 > /sys/devices/system/gpu/volt_table
echo 800 1200 > /sys/devices/system/gpu/volt_table
echo 160 > /sys/devices/system/gpu/min_freq
echo 640 > /sys/devices/system/gpu/max_freq
echo 80 10 > /sys/devices/system/gpu/thresholds
echo "85" > /sys/devices/system/cpu/cpufreq/pegasusq/up_threshold
echo "40" > /sys/devices/system/cpu/cpufreq/pegasusq/up_threshold_at_min_freq
echo "40000" > /sys/devices/system/cpu/cpufreq/pegasusq/sampling_rate
echo "1" > /sys/devices/system/cpu/cpufreq/pegasusq/io_is_busy
echo "300000" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_for_responsiveness
echo "10" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_step
echo "1" > /sys/devices/system/cpu/cpufreq/pegasusq/sampling_down_factor
echo "5" > /sys/devices/system/cpu/cpufreq/pegasusq/down_differential
echo "400000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_1_1
echo "200000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_2_0
echo "500000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_2_1
echo "300000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_3_0
echo "600000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_3_1
echo "400000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_4_0
echo "100" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_1_1
echo "100" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_2_0
echo "200" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_2_1
echo "200" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_3_0
echo "300" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_3_1
echo "300" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_4_0
echo "10" > /sys/devices/system/cpu/cpufreq/pegasusq/cpu_up_rate
echo "20" > /sys/devices/system/cpu/cpufreq/pegasusq/cpu_down_rate
echo "900000" >/sys/devices/system/cpufreq/pegasusq/flexrate_max_freq
echo ""
#UV_END#
echo "Insanity Volt Scheduler finished at $( date +"%m-%d-%Y %H:%M:%S" )" | tee -a $LOG_FILE;
Ultima modifica di frankcilo; 15-11-12 alle 23:23
Ciao CIS,io no lo stesso problema,che dialer devo attivare per ripristinare la registrazione?Altra cosa,da quando ho su la tua rom ho notato che quando ricevo chiamate mi esce nella tendina una notifica che mi avverte della possibilità di rispondere con comando vocale,dove posso disabilitare tale funzione che a me non serve?Grazie
in s voice trovi l'opzione comandi vocali....deflagga le opzioni che non interessano!
S voce ce l ho disattivato proprio....
