Racconta anche a noi suuu
Uah... stesso risultato!
Diteci qualcosa suuu
Se ti sono stato d'aiuto un Thanks è sempre gradito
Nuovo mio script aggiornato
#!/system/bin/sh
## Voltage Control boot script by xan and nitr8 ##
LOG_FILE=/data/volt_scheduler.log
rm -Rf $LOG_FILE
echo "Starting Insanity Volt Scheduler $( date +"%m-%d-%Y %H:%M:%S" )" | tee -a $LOG_FILE;
echo "Sleeping for 20 seconds to workaround oc not setting properly on stock derivatve roms..."
sleep 20
echo "Ok lets start working"
echo "Set MIN Scaling Frequency" | tee -a $LOG_FILE;
echo "200000" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
echo ""
echo "---------------"
echo "Set MAX Scaling Frequency" | tee -a $LOG_FILE;
echo "1800000" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
echo ""
echo "Set Scheduler for stl, bml and mmc" | tee -a $LOG_FILE;
for i in `ls /sys/block/stl*` /sys/block/bml* /sys/block/mmcblk* /sys/block/mtdblock* ; do
echo "sio" > $i/queue/scheduler;
echo "$i/queue/scheduler";
done;
echo "---------------";
echo "Set governor" | tee -a $LOG_FILE;
echo "pegasusq" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo ""
#UV_BEGIN#
echo "Set UV" | tee -a $LOG_FILE;
echo "1275 1225 1175 1150 1125 1100 1075 1050 1025 1000 975 950 925 900 875 850 825" > /sys/devices/system/cpu/cpu0/cpufreq/UV_mV_table
"GPU voltages " | tee -a $LOG_FILE;
echo "54 108 160 266 350 440 533 640 733 800" > /sys/devices/system/gpu/freq_table
echo 54 800 > /sys/devices/system/gpu/volt_table
echo 108 825 > /sys/devices/system/gpu/volt_table
echo 160 850 > /sys/devices/system/gpu/volt_table
echo 266 900 > /sys/devices/system/gpu/volt_table
echo 350 950 > /sys/devices/system/gpu/volt_table
echo 440 1000 > /sys/devices/system/gpu/volt_table
echo 533 1050 > /sys/devices/system/gpu/volt_table
echo 640 1100 > /sys/devices/system/gpu/volt_table
echo 733 1150 > /sys/devices/system/gpu/volt_table
echo 800 1200 > /sys/devices/system/gpu/volt_table
echo 160 > /sys/devices/system/gpu/min_freq
echo 640 > /sys/devices/system/gpu/max_freq
echo 85 10 > /sys/devices/system/gpu/thresholds
echo "85" > /sys/devices/system/cpu/cpufreq/pegasusq/up_threshold
echo "40" > /sys/devices/system/cpu/cpufreq/pegasusq/up_threshold_at_min_freq
echo "40000" > /sys/devices/system/cpu/cpufreq/pegasusq/sampling_rate
echo "1" > /sys/devices/system/cpu/cpufreq/pegasusq/io_is_busy
echo "300000" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_for_responsiveness
echo "10" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_step
echo "1" > /sys/devices/system/cpu/cpufreq/pegasusq/sampling_down_factor
echo "5" > /sys/devices/system/cpu/cpufreq/pegasusq/down_differential
echo "400000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_1_1
echo "200000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_2_0
echo "500000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_2_1
echo "300000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_3_0
echo "600000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_3_1
echo "400000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_4_0
echo "100" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_1_1
echo "100" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_2_0
echo "200" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_2_1
echo "200" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_3_0
echo "300" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_3_1
echo "300" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_4_0
echo "10" > /sys/devices/system/cpu/cpufreq/pegasusq/cpu_up_rate
echo "20" > /sys/devices/system/cpu/cpufreq/pegasusq/cpu_down_rate
echo "900000" > /sys/devices/system/cpu/cpufreq/pegasusq/flexrate_max_freq
echo "10" > /sys/devices/system/cpu/cpufreq/pegasusq/cpu_down_rate
echo ""
#UV_END#
echo "Insanity Volt Scheduler finished at $( date +"%m-%d-%Y %H:%M:%S" )" | tee -a $LOG_FILE;
Ultima modifica di frankcilo; 17-11-12 alle 07:15
keramik (16-11-12)
Ok. V16 con kernel redpil la suoneria è perfetta e non gracchia.
**inviato dal distruggi iphone galaxy note II **
scusa, in che file della cartella init.d vanno inseriti?
EDIT: trovato, va sostituito nel file S91voltctrl
Ultima modifica di matiu; 17-11-12 alle 00:02
Non rispondo a messaggi privati!
Le domande fatele sul forum.
Se non vi spiace dico la mia...
Capisco chi chiede come i nuovi utenti che kernel mettere e sono felicissimo che utenti più esperti vadano a cercare sempre il "limite" del kernel con cui si tovano meglio, ma tocca ad un certo punto fermarsi a riflettere... sono contento di quello che mi offre questo device con la rom cis80 con questo kernel che ho scelto? Si, no, posso cambiae? Certo è facilissimo! Non voglio essere frainteso, ma tutti i kernel che propongo sono kernel testati ognuno dei quali ha le sue peculiarità, il paragone con i vari programmi di benchmark è inutile, quello che realmente fa la differenza è l'uso reale, il resto sono chiacchiere da bar. Se volete seguitare a fare questi discorsi su quale kernel va meglio, apritevi una discussione apposta e fatevi i vostri raffronti, io mi dissocio perchè sò che in assoluto il kernel migliore è solo quello che fa quello che io voglio che faccia... ma io non sono tutti voi e quindi vi propongo varie possibilità e per i meno esperti offro una soluzione preconfigurata stock root, che va benissimo, per chi vuole smanettare c'è campo libero ed io offro tutti gli strumenti. Con il kernel di Angelo ci sono ancora dei problemi, per cui o rinuciate ad alcune mie scelte intraprese per la rom o rinunciate al suo kernel per avere il top, con altri kernel non ci sono problemi, se cancellate gli script in init.d fatelo con criterio e non a casaccio, perchè poi se avrete problemi sarà solo colpa vostra. Detto questo per i meno esperti consiglio il kernel stock preselezionato non a caso in fase di installazione, per gli utenti esperti fate secondo le vostre esigenze, io sono felicissimo di proporvi sempre il meglio e di inserire in rom pure le vostre proposte ma cerchiamo di non fare la "garetta".
Spero vi piaccia la v17, godetevela un pò, usate il costostoso device che avete tra le mani non solo per sviluppare o migliorare quacosa, ma per farci le cose per cui è stato creato, ed io ho cercato di migliorarlo, concludo con un'ultima mia considerazione personale, io vi propongo una rom con l'intento rendere migliore l'esperienza di utilizzo, privandovi di cose che al 90% sono inutili, offrendovi funzioni ed ottimizzazioni richieste o per lo meno apprezzabili da tutti... non offro una rom priva di tutto che fa 4 giorni di autonomia, come non offro una rom strabordante che occupa tutta la ram del device, vi propongo una scelta equilibrata e ottimizzata su cui potete a seconda delle vostre esigenze e capacità intervenire e l'ota èlo strumento che vi offro.
Buon proseguimento e scusatemi se non riesco a seguire il forum come vorrei
