Utente del giorno: Stahl con ben 18 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: Stahl con ben 107 Thanks ricevuti negli ultimi sette giorni
Utente del mese: Stahl con ben 439 Thanks ricevuti nell'ultimo mese
Pagina 13 di 292 primaprima ... 311121314152363113 ... ultimoultimo
Visualizzazione dei risultati da 121 a 130 su 2920
[KERNEL] Perseus *** script & altro !!!!
  1. #121
    Ringraziato 216 volte in 179 Posts
    Questo invece č lo script "equilibrato" o standard, ottima velocitā con un occhio ai consumi
    #!/system/bin/sh
    ## Voltage Control boot script by FrankCilo #####
    echo "200000" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
    echo ""
    echo "---------------"
    echo "1600000" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
    echo ""
    for i in `ls /sys/block/stl*` /sys/block/bml* /sys/block/mmcblk* /sys/block/mtdblock* ; do
    echo "sio" > $i/queue/scheduler;
    echo "$i/queue/scheduler";
    done;
    echo "---------------";
    echo "pegasusq" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
    echo ""
    #UV_BEGIN#
    echo "1275 1225 1175 1150 1125 1100 1075 1050 1025 1000 975 950 925 900 875 850 825" > /sys/devices/system/cpu/cpu0/cpufreq/UV_mV_table
    echo "54 108 160 266 350 440 533 640 733 800" > /sys/devices/system/gpu/freq_table
    echo 54 800 > /sys/devices/system/gpu/volt_table
    echo 108 825 > /sys/devices/system/gpu/volt_table
    echo 160 850 > /sys/devices/system/gpu/volt_table
    echo 266 900 > /sys/devices/system/gpu/volt_table
    echo 350 950 > /sys/devices/system/gpu/volt_table
    echo 440 1000 > /sys/devices/system/gpu/volt_table
    echo 533 1050 > /sys/devices/system/gpu/volt_table
    echo 640 1100 > /sys/devices/system/gpu/volt_table
    echo 733 1150 > /sys/devices/system/gpu/volt_table
    echo 800 1200 > /sys/devices/system/gpu/volt_table
    echo 160 > /sys/devices/system/gpu/min_freq
    echo 533 > /sys/devices/system/gpu/max_freq
    echo 50 10 > /sys/devices/system/gpu/thresholds
    echo "80" > /sys/devices/system/cpu/cpufreq/pegasusq/up_threshold
    echo "40" > /sys/devices/system/cpu/cpufreq/pegasusq/up_threshold_at_min_freq
    echo "40000" > /sys/devices/system/cpu/cpufreq/pegasusq/sampling_rate
    echo "0" > /sys/devices/system/cpu/cpufreq/pegasusq/io_is_busy
    echo "200000" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_for_responsiveness
    echo "5" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_step
    echo "1" > /sys/devices/system/cpu/cpufreq/pegasusq/sampling_down_factor
    echo "5" > /sys/devices/system/cpu/cpufreq/pegasusq/down_differential
    echo "300000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_1_1
    echo "100000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_2_0
    echo "400000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_2_1
    echo "200000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_3_0
    echo "500000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_3_1
    echo "200000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_4_0
    echo "100" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_1_1
    echo "100" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_2_0
    echo "250" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_2_1
    echo "250" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_3_0
    echo "350" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_3_1
    echo "350" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_4_0
    echo "10" > /sys/devices/system/cpu/cpufreq/pegasusq/cpu_up_rate
    echo "30" > /sys/devices/system/cpu/cpufreq/pegasusq/cpu_down_rate
    echo "800000" > /sys/devices/system/cpu/cpufreq/pegasusq/flexrate_max_freq
    echo "600000" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_for_fast_down
    echo "20" > /sys/devices/system/cpu/cpufreq/pegasusq/cpu_online_bias_down_threshold
    echo "50" > /sys/devices/system/cpu/cpufreq/pegasusq/cpu_online_bias_up_threshold
    echo "5" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_step_dec
    echo "90" > /sys/devices/system/cpu/cpufreq/pegasusq/up_threshold_at_fast_down
    echo "sio" > /sys/block/mmcblk0/queue/scheduler
    echo ""
    #UV_END#
    Ultima modifica di frankcilo; 11-12-12 alle 00:22
  2. Il seguente Utente ha ringraziato frankcilo per il post:
    nuvolaz (11-12-12)
    Questo, infine, per chi vuole il massimo... ma senza consumare troppo!
    #!/system/bin/sh
    echo ""
    echo "1800000" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
    echo ""
    done;
    echo ""
    #UV_BEGIN#
    echo 640 > /sys/devices/system/gpu/max_freq
    echo "30000" > /sys/devices/system/cpu/cpufreq/pegasusq/sampling_rate
    echo "10" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_step
    echo "10" > /sys/devices/system/cpu/cpufreq/pegasusq/down_differential
    echo "200" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_2_1
    echo "200" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_3_0
    echo "35" > /sys/devices/system/cpu/cpufreq/pegasusq/cpu_down_rate
    echo ""
    #UV_END#
  5. Il seguente Utente ha ringraziato frankcilo per il post:
    nuvolaz (11-12-12)
  6. #123
    Androidiano VIP L'avatar di pegliese93
    Localitā
    Liguria, Genova
    Ringraziato 671 volte in 442 Posts
    Ah ok allora aggiorno grazie te quali preferisci? Restare sui 1600 standard ?
    Se ti sono stato d'aiuto un Thanks č sempre gradito
  7. #124
    Infine chicca finale per chi sta sempre con il note2 con schermo accesso e vuole ottimi consumi ma reattivitā.
    La frequenza minima č impostata a 500mhz, ma non deve trarre in inganno, avrete gli stessi consumi! (Provare per credere!)
    #!/system/bin/sh
    echo "500000" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
    echo ""
    echo "1000000" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
    echo ""
    done;
    echo ""
    #UV_BEGIN#
    echo "500000" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_for_responsiveness
    echo "2" > /sys/devices/system/cpu/cpufreq/pegasusq/sampling_down_factor
    echo "700000" > /sys/devices/system/cpu/cpufreq/pegasusq/flexrate_max_freq
    echo ""
    #UV_END#
  8. Il seguente Utente ha ringraziato frankcilo per il post:
    nuvolaz (11-12-12)
  9. #125
    Quote Originariamente inviato da pegliese93 Visualizza il messaggio
    Diciamo che mi sto divertendo con quest'ultimo!
  10. #126
    Localitā
    Liguria, Genova
    Quote Originariamente inviato da frankcilo Visualizza il messaggio
    Immaginavo
  11. #127
    Senior Droid L'avatar di keramik
    Localitā
    SR
    GS-I9505 Blumak2000 3.0
    Ringraziato 46 volte in 41 Posts
    Caspita ragazzi, questo thread sembra il campo dei miracoli! Complimenti per i continui aggiornamenti e buon lavoro!
    Sent from my Cis80-GT-N7100-290dpi mod!
  12. #128
    Localitā
    Liguria, Genova
    Quote Originariamente inviato da keramik Visualizza il messaggio
    Grazie mille spero sia tutto abbastanza dettagliato ho dovuto sistemare in quella maniera altrimenti faccio una pagina ad ogni script a furia di ripetere le stesse cose
  13. #129
    Localitā
    SR
    Capisco, infatti..
    Io mi son fatto una cartella su extSD con una raccolta di tutti gli S91VOLTCTRL per il Perseus, modificati con i vari script proposti nel thread e temporaneamente rinominati in modo da distinguerli a primo colpo
    Una collezione! Ahhaha
  14. Il seguente Utente ha ringraziato keramik per il post:
    nuvolaz (11-12-12)
  15. #130
    Localitā
    Liguria, Genova
    Capisco, infatti..
    Belin addirittura ?? Mi sento onorato ma il merito č principalmente di frankcilo per i suoi meravigliosi script
