Proprio su tutto? Proprietario, Gruppo, Altri ed Autorizzazioni speciali (Set UID, set GID, Sticky)?
<------Ringraziami con un Thanks se ti sono stato d'aiuto: non costa nulla!
Device: Galaxy Note 2 n7100 - Marble White - No Brand
Wicked ROM [XXDLL4]
Kernel: Perseus 31.2
Recovery: CWM PhilZ Touch
Sì. .. meglio abbondare!
nuvolaz (11-12-12)
Wicked ROM [XXDLL4]
Aggiornamento script 1200mhz.
Per tutti gli script risolto il problema delloscheduler che non veniva modificato, aggiungere sleep 30 all'inizio dello script. Vedete di seguito:
#!/system/bin/sh
## Voltage Control boot script by FrankCilo #####
sleep 30
echo "200000" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
echo ""
echo "---------------"
echo "1200000" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
echo ""
for i in `ls /sys/block/stl*` /sys/block/bml* /sys/block/mmcblk* /sys/block/mtdblock* ; do
echo "noop" > $i/queue/scheduler;
echo "$i/queue/scheduler";
done;
echo "---------------";
echo "pegasusq" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo ""
#UV_BEGIN#
echo "1275 1225 1175 1150 1125 1100 1075 1050 1025 1000 975 950 925 900 875 850 825" > /sys/devices/system/cpu/cpu0/cpufreq/UV_mV_table
echo "54 108 160 266 350 440 533 640 733 800" > /sys/devices/system/gpu/freq_table
echo 54 800 > /sys/devices/system/gpu/volt_table
echo 108 825 > /sys/devices/system/gpu/volt_table
echo 160 850 > /sys/devices/system/gpu/volt_table
echo 266 900 > /sys/devices/system/gpu/volt_table
echo 350 950 > /sys/devices/system/gpu/volt_table
echo 440 1000 > /sys/devices/system/gpu/volt_table
echo 533 1050 > /sys/devices/system/gpu/volt_table
echo 640 1100 > /sys/devices/system/gpu/volt_table
echo 733 1150 > /sys/devices/system/gpu/volt_table
echo 800 1200 > /sys/devices/system/gpu/volt_table
echo 160 > /sys/devices/system/gpu/min_freq
echo 533 > /sys/devices/system/gpu/max_freq
echo 50 10 > /sys/devices/system/gpu/thresholds
echo "85" > /sys/devices/system/cpu/cpufreq/pegasusq/up_threshold
echo "40" > /sys/devices/system/cpu/cpufreq/pegasusq/up_threshold_at_min_freq
echo "30000" > /sys/devices/system/cpu/cpufreq/pegasusq/sampling_rate
echo "0" > /sys/devices/system/cpu/cpufreq/pegasusq/io_is_busy
echo "200000" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_for_responsiveness
echo "5" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_step
echo "1" > /sys/devices/system/cpu/cpufreq/pegasusq/sampling_down_factor
echo "5" > /sys/devices/system/cpu/cpufreq/pegasusq/down_differential
echo "300000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_1_1
echo "100000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_2_0
echo "400000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_2_1
echo "200000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_3_0
echo "500000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_3_1
echo "300000" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_freq_4_0
echo "100" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_1_1
echo "100" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_2_0
echo "250" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_2_1
echo "250" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_3_0
echo "350" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_3_1
echo "350" > /sys/devices/system/cpu/cpufreq/pegasusq/hotplug_rq_4_0
echo "10" > /sys/devices/system/cpu/cpufreq/pegasusq/cpu_up_rate
echo "30" > /sys/devices/system/cpu/cpufreq/pegasusq/cpu_down_rate
echo "800000" > /sys/devices/system/cpu/cpufreq/pegasusq/flexrate_max_freq
echo "600000" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_for_fast_down
echo "20" > /sys/devices/system/cpu/cpufreq/pegasusq/cpu_online_bias_down_threshold
echo "50" > /sys/devices/system/cpu/cpufreq/pegasusq/cpu_online_bias_up_threshold
echo "5" > /sys/devices/system/cpu/cpufreq/pegasusq/freq_step_dec
echo "90" > /sys/devices/system/cpu/cpufreq/pegasusq/up_threshold_at_fast_down
echo "noop" > /sys/block/mmcblk0/queue/scheduler
echo ""
#UV_END#
Basta aggiungere sleep 30 anche agli altri
Script aggiornati! per chi non l'avesse visto dovete inserire sleep 30 a inizio script come nelle guide o come da foto
Se ti sono stato d'aiuto un Thanks è sempre gradito
Domanda stupida, a me quando incollonil testo nel file da editare la formattazione del codice non viene come gli script postati qui ma una scritta tutta continua... Crea problemi e soprattutto come posso riportare la stessa formattazione del testo nel file? Non vorrei che per questo fatto nn funzionasse lo script perché ho notato che setcpu mi legge valori sempre di 200 Min e 1600max con qualsiasi script...
Per capirci il mio script diventa così...
