codice:
C:\Users\Marco\Desktop\apktool>apktool d SimplisticControl.apk
I: Baksmaling...
I: Loading resource table...
I: Loaded.
I: Decoding AndroidManifest.xml with resources...
I: Loading resource table from file: C:\Users\Marco\apktool\framework\1.apk
I: Loaded.
I: Regular manifest package...
I: Decoding file-resources...
I: Decoding values */* XMLs...
I: Done.
I: Copying assets and libs...
C:\Users\Marco\Desktop\apktool>apktool b SimplisticControl
I: Checking whether sources has changed...
I: Smaling...
I: Checking whether resources has changed...
I: Building resources...
C:\Users\Marco\Desktop\apktool\SimplisticControl\res\values\public.xml:77: error
: Public entry identifier 0x7f050020 entry index is larger than available symbol
s (index 32, total symbols 32).
: Public symbol array/toggles_bg_entries declared here is not defined.
C:\Users\Marco\Desktop\apktool\SimplisticControl\res\values\public.xml:78: error
: Public entry identifier 0x7f050021 entry index is larger than available symbol
s (index 33, total symbols 32).
: Public symbol array/toggles_bg_values declared here is not defined.
C:\Users\Marco\Desktop\apktool\SimplisticControl\res\values\public.xml:75: error
: Public symbol array/toggles_officon_entries declared here is not defined.
C:\Users\Marco\Desktop\apktool\SimplisticControl\res\values\public.xml:76: error
: Public symbol array/toggles_officon_values declared here is not defined.
Exception in thread "main" brut.androlib.AndrolibException: brut.androlib.Androl
ibException: brut.common.BrutException: could not exec command: [aapt, p, --min-
sdk-version, 16, --target-sdk-version, 17, -F, C:\Users\Marco\AppData\Local\Temp
\APKTOOL3399038374307537932.tmp, -0, arsc, -I, C:\Users\Marco\apktool\framework\
1.apk, -S, C:\Users\Marco\Desktop\apktool\SimplisticControl\res, -M, C:\Users\Ma
rco\Desktop\apktool\SimplisticControl\AndroidManifest.xml]
at brut.androlib.Androlib.buildResourcesFull(Androlib.java:358)
at brut.androlib.Androlib.buildResources(Androlib.java:283)
at brut.androlib.Androlib.build(Androlib.java:206)
at brut.androlib.Androlib.build(Androlib.java:176)
at brut.apktool.Main.cmdBuild(Main.java:228)
at brut.apktool.Main.main(Main.java:79)
Caused by: brut.androlib.AndrolibException: brut.common.BrutException: could not
exec command: [aapt, p, --min-sdk-version, 16, --target-sdk-version, 17, -F, C:
\Users\Marco\AppData\Local\Temp\APKTOOL3399038374307537932.tmp, -0, arsc, -I, C:
\Users\Marco\apktool\framework\1.apk, -S, C:\Users\Marco\Desktop\apktool\Simplis
ticControl\res, -M, C:\Users\Marco\Desktop\apktool\SimplisticControl\AndroidMani
fest.xml]
at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.jav
a:357)
at brut.androlib.Androlib.buildResourcesFull(Androlib.java:336)
... 5 more
Caused by: brut.common.BrutException: could not exec command: [aapt, p, --min-sd
k-version, 16, --target-sdk-version, 17, -F, C:\Users\Marco\AppData\Local\Temp\A
PKTOOL3399038374307537932.tmp, -0, arsc, -I, C:\Users\Marco\apktool\framework\1.
apk, -S, C:\Users\Marco\Desktop\apktool\SimplisticControl\res, -M, C:\Users\Marc
at brut.util.OS.exec(OS.java:89)
a:355)
... 6 more
