Utente del giorno: DreamReaper con ben 7 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: Stahl con ben 35 Thanks ricevuti negli ultimi sette giorni
Utente del mese: Stahl con ben 193 Thanks ricevuti nell'ultimo mese
Pagina 21 di 30 primaprima ... 111920212223 ... ultimoultimo
Visualizzazione dei risultati da 201 a 210 su 291
[KERNEL][4.4.x | 4.3 | 4.1.2][Samsung tw rom] AGNI pure stock - OC, ULTRASMOOTH
  1. #201
    bergamo
    Note Edge.Note2.Mi band
    Ho la Ketan
    Androidiano L'avatar di Robyj80
    Apr 2011
    OK io ho la DN4 con le vecchie release per adesso nessun problema, questa la devo ancora provare, ma sembrano tutte molto simili, quindi non credo di cambiare per adesso..
  4. #203
    Moderatore L'avatar di 8thphloor
    ONEPLUS2, NOTE2, NEXUS 7 2013
    Ringraziato 2,942 volte in 1,613 Posts
    • 30-04-2015 Update v4.4.1
      drivers/usb/gadget: add required modifications for CM builds | Accumulative squashed fixes + changes from SAMSUNG OSRC I9305 Update | Revised AGNi Control profiles v2.0 | Revised AGNi Control CPU-UV v2.0 based on device's detected asv_level
    Reuploaded repacked v4.4.1:-
    • Revised AGNi Control CPU-UV v2.0 based on device's detected asv_level
    Device's asv level is detected (0 to 12) and corresponding cpu-uv scripts for that asv are shown in agni control
    Advantages:-
    • Each device can be undervolted according to its original optimal chip voltages as categorised by asv_level.
    • One can know accurately how much device is capable of undervolting.
    • Undervolting not done on basis of arbitrary cpu voltages (EARLIER, CPU UNDERVOLTING WAS DONE ON BASIS OF MY ASV_LEVEL 4 DEVICE).
    • Brings similarity in level of undervolting for most users as arbitrary base values from one device of particular ASV will not be stable on other device of different ASV. (this is reason of uv voltages being working good for one, and unstable for another).
    • Further, in v2.0 of AGNi Control cpu-uv, the overclocking frequencies (2000,1920,1800,1704 MHz) are not undervolted. Also, low cpu frequencies (200,300 MHz) are not undervolted and stay on device's optimal voltages; this helps reduce chances of SOD's due to cpu dying out of power resulting from low voltages on low frequencies.
    • Effectively, cpu frequencies 1600 - 400 MHz can be undervolted from AGNi Control.
    • Now AGNi Control shows one's device's ASV_LEVEL in CPU UV area. A device of ASV_LEVEL of 0 means it needs more power (higher voltage) to operate optimally than a device of higher ASV_LEVEL.
    Ultima modifica di 8thphloor; 01-05-15 alle 03:17
    The answer to the ultimate question of life, the universe and everything is:
    CLEAN FLASH
  5. I seguenti 2 Utenti hanno ringraziato 8thphloor per il post:
    diegolandia1981 (01-05-15),NiloGlock (01-05-15)
  6. #204
    Sassari
    LG G2, LeMax 2
    Ringraziato 6,804 volte in 5,293 Posts
    Per quando riguarda il backup dell'attuale configurazione eseguibile dall'AGNi Control (utile in quanto ad ogni aggiornamento viene ripristinata quella di default), dove viene salvato di preciso?
    Smartphone:
  7. #205
    bergamo
    A me su rom ketan a parte il mio solito problema iniziale che a volte se si spegne display non si accende più e devo forzare riavvio. Che risolvo cambiando i vari settaggi che tanto quelli di default non mi piacciono. X il resto come kernel va bene.
  8. #206
    Apr 2011
    Io l'ho montata sulla Dn4 per adesso tutto OK ma va come era la 4.3.9 nessun cambiamento...
  9. #207
    Apr 2011
    Sono tornato alla 4.3.9. Perche l'ultima versione mi dava problemi di SOD...
  10. #208
    Sassari
    LG G2, LeMax 2
    Quote Originariamente inviato da Robyj80 Visualizza il messaggio
    Hai provato a fare un wipe cache ed un wipe dalvik cache? Dall'app hai modificato qualche parametro in particolare?
    Smartphone:
  11. #209
    Apr 2011
    Non ho provato, a te funziona?
  12. #210
    Apr 2011
    Ho provato 30 minuti fa... Non funziona... Tornato alla 4.3.9
