Uscita la nuova versione
Originariamente inviato da psndna8815-04-2014 Update v3.9.5
switch to GCC 4.8.3 linaro cortex-a9 optimised toolchain | fixed zram0 not turning off when turning off Zrams by AGNi Control | Applied some f2fs related commits | fixed "Encryption Unsuccessful" errors (now u can use /system as ext4 with /data as f2fs) | changed some mount options | completely removed ASYNC_FSYNC | added option to enable/disable dynamic fsync | added option to enable/disable on-boot filesystems checking (ext4/f2fs) log placed on internal storage | added option to delete battery stats on each boot | implemented AROMA GUI installer v2.70 RC2 with boeffla sound and wolfson sound selectables | set ROW as default from now on | Reduced F2FS active_logs from 6 to 2 | disabled Dynamic Fsync by default | set internalsd and externalsd read_ahead_kb to 512 & 1024 respectively | implemented Zzmoove v0.8 with all Zzmoove v0.8 profiles | LMK updated | added ExternalSd USB UMS switching option | logger: reduce reserved memory | mm/page_io: remove duplicated compressed pages in memory | ARM: implement flush_cache_louis() | cpufreq: Manage only online cpus | sync cm kernel commits | reworked AGNi Profiles and backup/restore | Updated Ramdisk to NA1 base | solved "[DEBUG] getprocattrcon: read failed, errno=22" error thrown by init | AROMA Installer now has SElinux Disabled and Permissive option
this time fixed my derp causing the misleading "/data corrupt" error
