che recoveri hai?
perche la philz 6.qualcosa a me ha dato questo problema
laa 5.15 no
Emanuelbruno1993 (21-12-13)
Ciao a tutti
Ho flashato la 15 e poi la 15.7..tutto ok a parte qualche piccolo lag qua e la..unico problema non riesco a farci girare il Sygic..appena lo lancio va in arresto forzato..qualcuno mi conferma??
Nessuno ha provato???
Comunque segnalo anche alcuni blocchi..
segnalo che è in upload la v. 16 su base ultimissima ML3
V16.0 PhoeniX 1 Year Anniversary Special Edition:
New in v16.0:
Rebuilt rom for 0! Rebased on the latest Official Android 4.3 version XXUEML3 (build date: 09/12/2013)
Stock customized kernel by me:
- SELinux set to permissive!!
- Insecured boot.img for full Root Access
- Init.d Support
- ExFat Support
This ROM is 200% Knox Free - You can say "Cya Knox!"
New Note 3 Gallery with all functions
Updated all Note 3 apps from MK2 base
New superb & amazing 4 PhoeniX Wallpapers made by anbech! You can also download these wallpapers to your computer here:
xda-developers
New smooth tweak built in the ROM! It is hell smooth now!
New Improved S-Browser
New Improved PullUp behavior
New PhoeniX Mods's protection - Well, apparently some clowns think they can take my mods without giving credits or asking for permissions. I won't allow that. This protection shouldn't bother you if you use PhoeniX ROM. When these mods are used on other rom, they simply won't work
Note3 mods for other ROMs based on ML3 will be published without protection on Note 3 Project thread.
New Improved Note 3 Touchwiz.
New Improved Air Command pictures
New SMS app Mods:
- Folder View Option
- Backup/Restore SMS Option
- Split view option
- Change text size using volume keys option
- Screen On/Off for notification alerts option
- and more!!
New Story Album
New Note 3 Installation Wizard(First setup)
New PhoeniX Logo in Settings -> About
AllShare is default in the ROM - needed for Wifi direct and screen mirroring.
Improved Watercolor Effect
Added Wether & Calendar widget when pulling down the clock on lockscreen.
New Note 3 Widgets (Like alarm widget)
Enabled IP Call for SIP users
Removed:
Readers Hub
Bye Bye Knox
Fixed:
Fixed Screen Mirroring - Fully working now.
Fixed Smart Pause & Smart Scrolling - Now they are working perfect!
Fixed Clipboard problem
Fixed Sound problems when taking a screenshot
Fixed apps' cut name on 5X6 touchwiz mods
Fixed Snote3 in 240DPI
Fixed YouTube in Scrapbook - Important!! DO NOT update youtube ! If you update you will lose this function. This is Samsung / YouTube bug.
Fixed TouchWiz EasyMod for some people here.
Fixed SPlanner Writing Mod
Updated:
136 CSCs. CSC Version: N7100OLBEML1. How to change CSC?
First, install Stock Android Recovery
Second, select your CSC and install.
Third, Install PhilZ/TWRP recovery
Enjoy
Updated all mods in the Aroma - All mods are available to install!(Some removed, see Aroma Log)
Updated busybox to the latest version
Updated Apps to their latest version:
- Google Plus
- ES File explorer
- Adobe Flash Player
- GMS Core
- Play Store
- DropBox
- Gmail
- SPPush client
- Samsung apps
- Chaton
- Samsung IAP
- Chrome
- Earth
- Voice Search
- Update Samsung Allshare to Samsung Link
- Hangouts
- SuperSU to 1.86
- And more
____________________o____________________
[ROM&KERNEL]: Sempre alla ricerca della migliore combinazione
Ma su xda nn c'è
Sicuro che la base sia ml9 invece di mk9?
Inviato dal mio Super S6 super moddato!!!
Se ti sono stato d'aiuto premi il tasto thanks.
su xda è ancora in upload come scritto quindi il dev non ha ancora aggiornato l'OP.
il changelog preview però l'ha pubblicato in un post e io l'ho riportato
@simoboy89 leggi la prima riga del nuovo changelog. L'ML3 è l'ultima release ufficiale rilasciata da samsung pochi giorni fa, penso sia uscita in india o giu di li
L'ultima versione in upload ora la v16 , sarebbe bello da confrontare con la ditto 3.1.1 .
