ResurrectionRemix #Lollipop 5.1.0_r5 - v5.4.2
The Changelog
- Anadroid update 5.1.0_r5
- Only go HOME if screen is fully awake
- Fixing memory leak in RenderBufferCache
- Fix DataInputStream leaks
- inputservice: Allow disabling the usage of cursor layers.
- QS: change live display off color to grey
- Forward port pattern visibility settings
- forward port lock pattern grid size
- fix race condition with occluded keyguard on non-navbar devices
- Add USB Tether tile
- Fix signal annunciators missing issue.
- Add music tile
- Restore proper ringtone for msim
- EdgeGesture service: add more sensitivity steps
- Automatic translation imports
- Fix screen pinning averting soft reboot
- Zen mode add 10 and 12 hours downtime
- Screenshots info is not updated when device is plugged in MTP mode
- Modify the display of system default ringtone when it is none.
- Find wall clock RTC through sysfs
- Show operator name UI after getting valid operator name
- third part apps can disable the secret lockscreen
- Fix memory leak in Connectivity Service when phone app crashes
- Prevent unexpected rotation while going back to keyguard
- Optimize IncallUI delay for voice calls
- Fix an apk icon animation corruption issue
- restrict updateExternalMediaStatus to non-emulated storage
- Avoid duplicated calling to isRestricted to improve performance
- nat464X: Only update ipv4 pseudo-interface when it's connected
- always update volumes slider state
- Mobile data tile: open network settings
- Add a timeout state to frozen windows
- Allow screen unpinning on devices without navbar
- SystemUI: hide navigation bar faster in SetupWizard
- System UI: Improve Recents
- The DUT can't screen shot in guest mode
- Always show ZenPanel when showing expanded volume panel
- animate clear recents button on exit animation
- add CPU info overlay
- allow recent tasks to draw behind the status bar
- Statusbar header: Add vibration to settings button
- SystemUI: Update doze pulse-in option
- fix keyguard charging text not showing
- fix updating keyguard insecure lock icon
- WIFI Improvements
- Fix up torch tile handling.
- SystemUI: move keyguard visualizer behind notifications
- Bluetooth improvements
- Themes improvements
- Performance improvements and bug fixes
- includes Other cm 12.1 and AOSP updates
- For extended changelog, track github activities
t03g....non t03gub!!!
