Utente del giorno: DreamReaper con ben 12 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: DreamReaper con ben 58 Thanks ricevuti negli ultimi sette giorni
Utente del mese: DreamReaper con ben 179 Thanks ricevuti nell'ultimo mese
Pagina 23 di 63 primaprima ... 13212223242533 ... ultimoultimo
Visualizzazione dei risultati da 221 a 230 su 623
[ROM][LP][5.1.1r26] Resurrection Remix [CM 12.1/UBER 4.9]
  1. #221
    Mar 2015
    Io ho la philz recovery e me lo chiede già da solo se voglio installare una nuova rom.. Cmq credo che con i full wipe tu possa andare tranquillo!!
    Moderatore L'avatar di 8thphloor
    ONEPLUS2, NOTE2, NEXUS 7 2013
    Ringraziato 2,945 volte in 1,615 Posts
    Resurrection Remix Lollipop 5.1.1-r1 - v5.4.4
    Reorganized button settings
    SettingsProvider: Make the default battery style Circle
    SysUI: Add lockscreen visualizer for MSIM devices
    Themes: Pass ComposedIconInfo into createIconBitmap
    Themes: Add randomization to composed icon rotation
    frameworks: add ongoing notification while collecting bug report
    Re-add dump() method to TorchService
    TorchService: improve state management
    Themes: Translate before rotating composed icons
    QS: don't stay in vibrate mode when toggling to important interruptions
    Apply sounds on theme update
    Unset frame listener before tearing down GLThreadManager
    Torch: remind user flashlight is still on
    Doze: make brightness level and auto brightness configurable
    Fix fetching application context for ThemedUiContext.
    Fix NPE in NetdResponseCode.InterfaceClassActivity
    doze: Separate proximity check by reason
    GlobalActions: add zen mode buttons
    Set DataUsageTile button padding to 8
    Fix DataUsageTile button layout
    Themes: include new icon features in shouldComposeIcon()
    optimize wallpaper load,avoid show black wallpaper.
    SystemUI: bluetooth tile: fix disconnect action
    Fix ro.telephony.default_network setting parsing
    Fix no vibration during shutdown.
    SystemUI: small optimization for notification icon numbers
    ambient display: Fix volume key music control
    Base: enable/disable doze through Profiles
    Make minfree values optimal for 32bit devices
    Fix system server crash
    MediaSessionService: Error checks for UserRecord object
    libandroidfw: Fatal exception of dlfree often causes the system crashed
    Update carrier label / custom & change color
    Base: Second Clock
    Squashed: Status bar greeting & timeout + Statusbar logo & color
    Add missing import for navbar
    Add Gesture Lockscreen
    SystemUI: Use smaller battery padding
    Revert "Settings: use correct default value for backlight brightness"
    Settings: fix button back light restore logic
    Settings: use ActivityManager method for requesting bug report
    Settings: persist backlight brightness setting
    Update VibratorIntensity
    CryptKeeper: pattern unlock displays incorrect pw when correct
    Settings: disable mobile network switch when SIM isn't ready
    Settings: fix non lock pattern CryptKeeper crash
    Settings: fix bad MTP uncheck behavior
    Improve color picker:
    Color picker: Enable alpha slider as default
    Open app when clicking on icon in App Info screen
    hammerhead: mm-camera-interface: Retry in case of timeouts
    g3:Add HW keys config
    g3:GPS updates
    g3:Camera Updates
    g3:Switch to governor "conservative" for better performance results
    g3:Revert "Revert "ril: add support for sprint nonstandard SIM""
    g3:sepolicy: mpdecision: allow socket_device dir remove_name
    The answer to the ultimate question of life, the universe and everything is:
    CLEAN FLASH
  4. I seguenti 3 Utenti hanno ringraziato 8thphloor per il post:
    Coach85 (11-05-15),pomokiss (10-05-15),VEVVE (10-05-15)
  5. #223
    Mar 2015
    Già ero soddisfatto dell'ultima versione.. Ora lo aggiorno e chissà che vada ancora meglio..
  6. #224
    Scusate ma sono l'unico ha cui si freeza su schermo nero 10 volte al giorno?
  7. #225
    Mar 2015
    No.. A me succede un paio di volte a settimana però!!
    Visto che la cm12 riceve aggiornamenti tramite ota.. Quando questa rom potrà ricevere anch'essa aggiornamenti tramite ota??
  8. #226
    Nov 2013
    Galaxy Note 2, Meizu Pro5
    Secondo voi la cyano liscia è più stabile di questa
  9. #227
    Mar 2015
    Quote Originariamente inviato da skikky11 Visualizza il messaggio
    Essendo la RR basata sulla cm12.. Secondo me è più fluida la cm12..
  10. #228
    Quote Originariamente inviato da Coach85 Visualizza il messaggio
    quanto a stabilità e fluidità siamo lì...ovviamente la mamma cyano è più snella e con meno funzionalità il rischio di prpblemi è minore. inoltre le correzioni ai problemi vengono implementate prima su cyano e poi qui..insomma è una scelta personale
    Quote Originariamente inviato da neosemy Visualizza il messaggio
    sei partito da situazione pulita? usi kernel alternativi? perchè le ultime release sono piuttosto stabili...
    CLEAN FLASH
  11. #229
    [QUOTE= sei partito da situazione pulita? usi kernel alternativi? perchè le ultime release sono piuttosto stabili...[/QUOTE]
    Ho eseguito l'installazione come riportato.
    Venivo datto ditto 4 electron team
    Ho fatto gli wipe "factory reset" di twrp
    Installato rom, gapps,
    Al momento ho installato agni kernel proprio per cercare di migliorare la stabilità........
  12. #230
    Io ho riscontrato i seguenti bug ed a oggi non riesco a sistemarli:
    1) Il cell si pianta mentre ha il display spento.....praticamente se non lo tocco per un oretta è facile che lo ritrovi piantato. Per piantato intendo che non riesco a far riapparire il schermo e devo riavviarlo tenendo premuto il pulsante di accensione.
    2) Tutti i filmati e quelli di youtube soprattutto si piantano dopo 5 secondi di avvio con un problema non meglio identificato.....si riavvia ed il video riparte se nza blocchi
    3)Ho un Opel Zafira del 2013 e se lo collego al bluetooh dell'auto appena provo a chiamare il telefono perde completamente il segnale e per 10-12 secondi perde completamente l'operatore......quindi ad oggi inutilizzabile in auto
