Resurrection Remix Lollipop 5.1.1_r2 - v5.4.5
Android 5.1.1_r1 -> 5.1.1_r2
Allow overlaying default quick settings tiles
base: Fix notification sounds for wifi only devices …
Improve SeekBarVolumizer behavior with unlinked streams
policy: fix device sleeping with lid with incoming call
policy: respect FLAG_TURN_SCREEN_ON flag with device flip covers
PowerManagerService: Honor config_dreamsActivatedOnSleepByDefault
Change lock gesture correct color
Themes: Make parse() method in FontListParser public
frameworks: fix setting up linked notification stream on boot
Keyguard: reinflate security views after user change
Adding additional Nova theme identifier to legacy icon support.
Improve Recents-View
Telephony: Convert subscription ID to int from long
framework/base: add dock sd card string
QS: fix filtering additional tiles
SystemUI: Use smaller battery padding
Update lock weather widget layout
dozeui: Broadcast an intent when beginning a doze pulse
textclock: Update the time when performing a doze pulse
Remove resources.apk from ZipSet when removing overlay
TorchService: close all opened cameras
SystemUI: Fix EL translation
Fix setting hotspot bounds in a drawable container
Fix PackageManager crashes w/ queryIntent using callerUID of 0
SystemUI: Speed up and clean tests (squash)
FWB: Battery light: 100% charged level
SystemServer: Allow starting of overlaid external services.
SystemUI: Squash custom tile commits
base: Nat464: unregister network observer when we stop!
[ActivityManager] Avoid unnecessary restart provider process
SystemUI: Point to correct permission for BIND_CUSTOM_TILE_LISTENER
Notification drawer: Custom clear all icon color
Improve QSPanel.java
fixup volume stream linking
Clean up keyguard carrier text handling.
Remove some useless debug spam.
Revert "ConnectivityService: add persist.radio.noril"
SystemBars: Allow the StatusBarComponent be externally defined
KeyGuard: Fix the wrong Plmn/SPN display.
[ActivityManager] Move UI operation to UI handler
[ActivityManager] Fix activity always visible.
[ActivityManager] Finish the failed-to-pause activity
Profiles: make Default profile change ring mode back on
Fix navbar NPE
improve navbar switch
Improve PreviewsColumns Implementation
Don't dismiss keyguard if recreating status bar
Re-add missing ellipsis string
Fix LiveDisplay QS icon size.
Frameworks/base: Fix old code in MediaPlayer
Fix context leak
Sometimes the application context is null
Prevent windows from freezing screen while timeout
fix return value scale of notifyANR()
Check caller status precisely when registering receiver.
Also restart provider if there is external handle.
Fix lost singleton provider after force-stopping user or package.
Adjust display inversion matrix to account for luminance
Use the correct parent size to initialize animations
Don't apply animation clip to dialog activities
Settings : Update blacklist strings
Settings: update About screen device model fields
Custom clear all icon color remove dependency
Updated RU translation
Show Toast if usb not connected in Storage Settings
Settings: fix BT switch enabling discoverable mode
Used fixed size for app icon width in default sms dialog
Change Usb not connected string to capital letters.
Fix mobile network switch for CDMA phones
Do not allow privacy guard for core system apps.
msm8974-common: Use RIL version 10
msm8974: sepolicy: vold gets persist
bacon: Add more options For Ambient Display
g2: Add more options For Ambient Display
bacon: FIX Ghost touch issues
d855: Fix apps2sd to usb storage
g3:fix memory leak after return battery save mode
g3: Add the ability for call recording
g3:wcnss: update configs and firmware from V23C
g3:Fix cpu heating
bug Fixes and Performance improvments from cm
EDIT pare ci siano problemi col traffico dati 3g...meglio attendere per il flash
EDIT2 in arrivo nuova build con fix dati 3g http://forum.xda-developers.com/show...php?p=60858516
EDIT 3 LA NUOVA BUILD NON HA PROBLEMI COL 3G
