Pagina 29 di 63 primaprima ... 19272829303139 ... ultimoultimo
Visualizzazione dei risultati da 281 a 290 su 623
[ROM][LP][5.1.1r26] Resurrection Remix [CM 12.1/UBER 4.9]
  1. #281
    Moderatore L'avatar di 8thphloor
    ONEPLUS2, NOTE2, NEXUS 7 2013
    Ringraziato 2,944 volte in 1,616 Posts
    Resurrection Remix Lollipop 5.1.1_r3 - v5.4.6
    Android 5.1.1_r2 -> 5.1.1_r3
    New Bootanimation for XXXHDPI anx XXHPI devices (XHDPI AND HDPI will come soon)
    CryptKeeper: layout whole screen in bounds
    Settings: add marquee to Device administrators screen
    CryptKeeper improvements
    apps2sd: Enable apps2sd for apps with unspecified install location
    Exclude themes from being moved to external storage
    Keep the content when change the orientation
    apps2sd: Only allow move to _ if the media is mounted
    Status bar expanded header: Custom background color
    Settings: Add some more entries into 'SMS message limit' menu
    Kill off a few MSIM tab hosts.
    WakeLock: Layout Improvements
    Add option to set default custom function to button recents
    Add CAF Task Manager switch
    PackageManager: don't attempt to get theme on core boot
    Implement better legacy support for themes
    AudioService: persist volume of ring stream when ringer mode changed
    BaseStatusBar: Inform StatusBarService if a notification is flagged spam
    Make default overlay for "spell checker"
    Return original value if icon info is null
    Make ACCESS_THEME_MANAGER permission system|signature
    Measure absolute value of pointer motion distance
    Fix racing condition of mTouchExcludeRegion
    Only one task within the stack should moveToBack
    Don't relayout based on a window that isn't visible
    Remove the window whose client process has died or become zombie
    Fix bug of unnecessary wakeups after completed syncs.
    Fix for infinite loop in RemoteViewsAdapter
    Fix bugs regarding delay the dispatching of non-wakeup alarms
    SystemUI: improve dpad arrow key state logic
    DreamManager: be aware of device lid
    Recognized multiple wallpapers in theme
    VolumePanel: Properly update expanded volume panel sliders
    Fix tiles with custom colors toggle issues
    Fix clock seconds display with am/pm
    SystemUI: Move custom tile listener service registration to phonestatusbar
    Fix another off-by-one error in computeEllipsis
    Fix array bounds exception in getSecondaryStorageState …
    Add alternate WebView provider package
    SystemServer: Skip TorchService construction if no flash feature detected
    Revert to previous battery padding
    PackageManagerService: Create means of installing prebundled applications
    Allow sending vendor- or device-specific commands to the camera HAL
    Revert display: Added automatic brightness configs
    Increase brightness faster if ambient light is brightening quickly.
    systemui: notify everyone that lockscreen is not going to be shown
    Profiles: re-enable data toggling
    Remove unnecessary videos
    Theme reboot menu
    Themes: Fix Reboot Background
    SystemUI: Add task manager
    Fix ForceClose due to TaskManger.
    Expose task manager values for themers
    Materialize task kill button & Improve Task manager UI
    Modify GC Delay to include subsequent launches. (fix)
    Determine default 12/24 hour time format setting from locale.
    Allow changing status/navigation bars when styles selected
    ThemeChooser: add uninstall shortcut to ChooserDetailFragment
    Libcore: FIX google Play Services Crash
    translation Imports
    msm8974: Disable BLE peripheral mode
    msm8974: Update WCN configuration
    msm8974-common: Use RIL version 10
    g3: Fix cpu heating
    g2: Fix missing usbdisk0 in symlink and export
    g2 :fix usb-otg
    g2: FIX Double Tap to Wake For GOOD
    g2 :Fix 4k recording profile
    g2: gps: Update HALs from oppo msm8974
    sprout: Set DPI to 182
    smdk4412:audio: enable noise suppression by default
    hammerhead: Update build fingerprint and description to LMY48B
    hammerhead: Give unpriviledged users write perms to USB storage
    Moto : Add Moto Doze Mode
    Falcon/Titan : Add More options For Doze
    bacon: Add Linaro Optimizations to Fix google Play Services FC
    All Bug Fixes And performance Improvements From CM
    Admin Note: this thread has a dedicated questions and answers section which you can access here -->.
    The answer to the ultimate question of life, the universe and everything is:
    CLEAN FLASH
  2. I seguenti 2 Utenti hanno ringraziato 8thphloor per il post:
    Coach85 (30-05-15),pomokiss (31-05-15)
    Mar 2015
    "Disable hw overlays in developer options to get video working"
    Qualcuno riesce a capire cosa devo disattivare per far funzionare i video??
    Edit: problema risolto!! Andare su opzioni sviluppatore e disattivare hw overlays.. Si trova poco dopo la metà della lista.. I video poi iniziano a funzionare senza problemi..
    Edit2: mi è arrivato un aggiornamento tramite ota.. È possibile??
    Ultima modifica di Coach85; 01-06-15 alle 09:51
  5. Il seguente Utente ha ringraziato Coach85 per il post:
    pomokiss (31-05-15)
  6. #283
    Nov 2010
    Quote Originariamente inviato da Coach85 Visualizza il messaggio
    Anche a me arrivano aggiornamenti ota!
  7. #284
    Nov 2010
    Quote Originariamente inviato da krft72 Visualizza il messaggio
    Ciao a tutti, capita anche a voi che la fotocamera si blocca utilizzando wathapp?
    Ciao a tutti,
    il problema della fotocamera mi si presenta anche con cam scanner!
    E' possibile che siano le gaps che ho installato? Che ovviamente non ricordo?
    Grazie a tutti.
  8. #285
    Nov 2010
    [QUOTE=krft72;6881001]Ciao a tutti,
    Grazie a tutti.[/QUOTEDa solo
    Mi rispondo da solo, la stessa soluzione che risolve la riproduzione video risolve anche il problema alla fotocamera utilizzata in altre app come cam scanner e WhatsApp.
    Ciao
  9. #286
    New build uploading
    will be named Resurrection_Remix_LP_v5.4.6_optimized-20150601-n7100.zip
    ETA 20 mins
    based on latest cm sources
    -The buggy OTA pointing to CM should be removed
    -Video Playback should be fixed
    -Other Fixes from CM
    ..se il changelog è veritiero è un buon passo avanti...
    EDIT il bug di youtube è risolto e la riproduzione video funziona senza dover fare alcuna modifica in opzioni sviluppatore (si può fare a meno anche di awesome player). funziona anche il muoversi avanti e indietro in un video su browser..finalmente
    sto testando da qualche giorno l'abbinamento con agni 4.4.4 pure CM e sono davvero soddisfatto..grazie al boeffla sound anche i volumi in cuffia e speaker sono buoni..
    Ultima modifica di 8thphloor; 02-06-15 alle 00:53
    CLEAN FLASH
  10. Il seguente Utente ha ringraziato 8thphloor per il post:
    pomokiss (05-06-15)
  11. #287
    Mar 2015
    Ma allora si può aggiornare tramite ota??
  12. #288
    no...quelle notifiche arrivavano per un'errore. fanno parte del sistema di update della cm12.1 da cui deriva la resurrection. che però non prevede per il momento l'uso di questa funzionalità. con quest'ultimo aggiornamento sono state disabilitate
    CLEAN FLASH
  13. Il seguente Utente ha ringraziato 8thphloor per il post:
    Coach85 (02-06-15)
  14. #289
    Mar 2015
    Google play non funziona.. Ho provato due tipi di gapps..
    Ho solo fatto aggiornamento e non un'installazione pulita..
    Edit: Con installazione pulita tutto funziona.. Problema YouTube risolto..
    Ultima modifica di Coach85; 02-06-15 alle 13:10
  15. Il seguente Utente ha ringraziato Coach85 per il post:
    pomokiss (02-06-15)
  16. #290
    Tornato alla dn4 per il momento...avuto problemi con la memoria interna ed esterna (mi dava tutto a zero..). Non so se dovuto alla rom che si impallava troppo o problema hardware. .cambiata scheda madre e dopo 2 giorni, dopo aver avuto problemi con la cartella efs e dopo essere riuscito dopo vari tentativi a metterlo a posto, sono ripassato alla dn4...per il momento, meglio andare sul sicuro (o quasi) .attendo release più stabili. ..
