Eh lo so.. Se c'è la possibilità del multiwindows è una figata pazzesca!!
Resurrection Remix Lollipop 5.1.1 - v5.5.2
Add Dock Battery
Improve navbar layout
livedisplay: Fix issue where settings weren't applied
livedisplay: Round values up
MediaPlayer: Add multi SIM ringtone support
Revert CAF's default system sound settings
MediaScanner: Add support for default ringtones per sim
Fix mounting of non-FAT formatted SD cards
Track current user id in ThemeService
Authenticate When Keyguard Resumes From Camera
Fingerprint: Add break after MSG_REMOVED
Status bar expanded header: Custom background color
Fix some issues with themes and notif bg color
Add Screenrecorder To Power Menu and Quick Settings
SettingsProvider: Update action for Profile picker.
Powermenu: screenshot delay
SystemUI: update notification clipping when reset
PhoneNumberUtils: Add rewrite rule for CDMA networks in Ukraine
GA = Fix size of close putton drawables
SystemUI: SlimDim
SlimDim: listen for touches in navbar empty areas also
SystemUI: SlimDim - pref to listen on entire screen for touches
SystemUI: fix battery icon jump on qs expand
Fix GPS for old GPS HALs
CYNGNOS-489: Fingerprint: Fix concurrent mod exception when getting Fingerprint list
Add fingerprint enrollment stats
Settings: Hide carrier on lock screen
Add LOCKSCREEN_BIOMETRIC_WEAK_FALLBACK to fallbackIntent
OOBE: Set next label when fingerprint enrollment done
Add battery saver settings to power usage summary
Light settings: reduce tone if preview image color is very light
Remove manage fingerprints from enrollment setup
Use theme_accent for manage_fingerptins_primary_color
Fingerprint: Cancel timeout if user leaves enrollment
Settings: hide light pulse settings if not available
Fingerprint: Match Enrollment UI with SetupWizard
Fix navigating fallback security via setup wizard
Fix aliasing in FingerprintProgressBar
Fingerprint: Include "Fingerprint" in the unlock title
Settings: fix setting light FC
Protected Apps: Monitor unlock status
Keep screen on during fingerprint enrollment
Fix protected apps orientation
Add protected apps configChanges orientation
Fix config_proximityCheckOnWake setting handling
Remove hardcoded textAppearance for better theme support
Settings:add japanese translation
Setup: Call setUseFingerprint() when enrollment finished
Settings: Make sure we're getting the instance of ProfileManager.
Settings: add Kiev time zones to picker
Fix Battery % display in saver threshold
Settings: Hide radio band selection based on config
vendor/cm: Introduce update-cm-prebuilts-latest-public-api.
vendor/cm: Clean up paths to known files.
Fix Rogers APN
APN fine tuning
rendang: Remove unwanted APNs
Hack in support for the old version of Maven
Themes:Update iconography.
Inlcludes All bug fixes and performanced updates from cyanogenmod
For More Information Track github activities
The answer to the ultimate question of life, the universe and everything is:
CLEAN FLASH
VEVVE (23-07-15)
Appena aggiornato, in mezz'ora 3 reset del telefono.
Non mi sembra funzioni un gran ché.
CLEAN FLASH
HappyCactus (23-07-15)
Aggiornato, con clean della cache.
C'è da dire che di reboot ne ho avuti diversi in precedenza, a partire dalla prima che era ovviamente una installazione pulita e come si deve. La versione precedente sembrava aver risolto, però.
Proverò con il cambio del kernel come suggerito più sotto :-)
Thanks
Trovi tutto ciò di cui hai bisogno qui: https://www.androidiani.com/forum/sh...d.php?t=455036
• REGOLAMENTO • CONSIGLI SULL'UTILIZZO DEL FORUM • F.A.Q. DEL FORUM • MANUALE BBCODES •
Smartphone:
CLEAN FLASH
