Testato e funzionante su Windows 10... Sicuro di avere gli ultimi driver disponibili?
Comunque chiudo l'ot
• REGOLAMENTO • CONSIGLI SULL'UTILIZZO DEL FORUM • F.A.Q. DEL FORUM • MANUALE BBCODES •
Smartphone:
Risolto, era il cavo. Cambiato e tutto ok.
Scusate l'OT ma pensavo potesse essere un bug della ROM
Salve a tutti, qualcuno mi sa dire quale apk devo installare per usare xposed con questa rom?
[GUIDA] Xposed Framework per Android Lollipop [5.0/5.1]
Prima installi l'apk e poi flashi lo zip via recovery
Smartphone:
1pietro (07-09-15)
update bello corposo
# Resurrection Remix Lollipop 5.1.1 - v5.5.5
RR Configurations revamp > Add more categories > Change lots of icons - categories, and status bar
OmniSwitch
SystemUI: Fix blinking when reported battery level is 0
Improve statusbar RR logo
Status bar carrier label font size
systemui: left hand navigation ring
systemui: respect navigation rings configuration
Long press no longer copies to clipboard if there is nothing to copy
Improve configurations icons visibility (Non-transparent)
Protected apps: fixup rotation states
Settings: remove duplicate lockscreen shortcuts
zygote: fix memory leak when fork process
Show infinity for large notification counts
Bold settings headers
Update APNs
Lockscreen colors
SystemUI:Fix navbar power button overlapping when ime switcher shown
Let liblights adjust the brightness of LEDs while previewing it
Fingerprint: Allow disabling of vibration
SystemUI: hide taskmanager panel while keyguard is showing
SystemUI: reset to QS panel when swiping down
Chamber of Secrets.
Bold italic weather font style - More weather font styles
Add time-context headers to the notification header
RR Logo style --- left or right
hide qs tiles with sensitive data
selinux switch: getenforce() won't ask for SuperSU
Fix the cell standby mobile radio active issue
Toast icon switch
Added show volume panel tile to QS
LEDs Brightness Lights notifications brightness support
Lights with Screen On - Optional allowment of lights
SystemUI: do not load header bar if boot isn't complete
Add a controller for in-call proximity sensor & Disable Touch by Proximity Sensor
settings: Animation scale seekbars
Fix proximity Speaker
Fix for Hardware Buttons
SystemUI: SlimDim performance boosts
Show icon of package associated with Toast
Fix "Select correct 12 or 24 time format" breaking Chrome
LiveDisplay color profiles
SystemUI: Fade keyguard visualizer along with other icons
SystemUI: use new visualizer from Eleven
Settings: obey prevent accidental wakeup default
NetworkTraffic: Show/Hide Arrows
Modify SILENT profile to restrict notification sound
Fix Blank area appears between QS and Notification
Themes: Allow packages to be set as non-themeable
Settings: add Berlin to time zones list
Settings: add a way to reset quick settings tiles
Move CMHW to CMSDK
Disable Headsup floating by default
SignalStrength: Allow for custom signal buckets in LTE
base: don't refresh visualizer tile once the tile is destroyed
Device specific changes
Translations update (Settings, base, OTACenter)
CyanogenMod updates
For more details check commits on GitHub
Zip size of ROM is smaller now as it s compressed with lzma
The answer to the ultimate question of life, the universe and everything is:
CLEAN FLASH
VEVVE (07-09-15)
Ragazzi, come va questa rom a livello batteria? Al momento sono su Eclipse, consumi eccezionali in standby ma appena uso il telefono scende che è un piacere. Io amo android stock, la resurrection si comporta meglio?
Questa non è stock.. È aosp!! Se vuoi una Rom molto personalizzabile questa è il top.. Batteria nella norma.. Io una giornata ce la faccio con un uso intenso..
nancyboy (06-10-15)
Smartphone:
Coach85 (14-09-15)
CLEAN FLASH
nancyboy (06-10-15)
ciao a tutti, scusate se disturbo, sono un novellino in queste cose, volevo perciò chiedervi una informazione. Avevo intenzione di istallare questa Rom. Perciò ho prima flashato con Odin una custom recovery. Prima di flashare la rom dalla recovery, c'è scritto che conviene fare una pulizia generale. Sono tuttavia indeciso su cosa fare. Nella recovery mi dice che posso fare o un hard reset oppure advanced wipe (e selezionare, per fare una full wipe, tutte le voci). Quale delle due dovrei fare? c'è qualche differenza? inoltre dopo averlo pulito perdo i permessi di root e la recovery e quindi devo flashare nuovamente da Odin oppure poi mi basta solo flashare da recovery la rom? grazie
