sisi,intendevo quella,ma per passare da resurrection remix 5.1.1 a questa bastano i wipe giusto?
18-10-2015 Update v4.4.6 (Stock-sources based)
Zzmoove Version 1.0 beta8 | kernel: Replace timeconst.pl with a bc script | random updated | lmk: properly consider cached memory usable | Update LZ4 & sync with upstream (arter97) | Revert "mm: fix extra_free_kbytes tunable for CMA" | Revert "add extra free kbytes tunable" | sensors: cm36651: fix build with debugging enabled | drivers: net: usb: add support for ASIX AX88179 based USB ethernet adapters | nf: IDLETIMER: time-stamp and suspend/resume handling | extcon: adc-jack: Use power efficient workqueue | dm-crypt: allow trailing "0" argument for compat with Android 5.1.1 vold | Update f2fs and dependencies (arter97) | Disable CONFIG_CPU_FREQ_GOV_ONDEMAND_FLEXRATE
18-10-2015 Update v4.4.6(ANYROM+AROMA) (smdk4x12_Kitkat-Lolypop_official/old_builds)
Zzmoove Version 1.0 beta8 | kernel: Replace timeconst.pl with a bc script | random updated | lmk: properly consider cached memory usable | Update LZ4 & sync with upstream (arter97) | Revert "mm: fix extra_free_kbytes tunable for CMA" | Revert "add extra free kbytes tunable" | sensors: cm36651: fix build with debugging enabled | drivers: net: usb: add support for ASIX AX88179 based USB ethernet adapters | nf: IDLETIMER: time-stamp and suspend/resume handling | extcon: adc-jack: Use power efficient workqueue | Update f2fs and dependencies (arter97) | Disable CONFIG_CPU_FREQ_GOV_ONDEMAND_FLEXRATE
The answer to the ultimate question of life, the universe and everything is:
CLEAN FLASH
25-10-2015 Update v4.4.7 (Stock-sources based)
accessory: fix false disconnect due to a signal sent to the reading process | pstore: selinux: add security in-core xattr support for rootfs, pstore and debugfs | tcp: add a sysctl to config the tcp_default_init_rwnd | misc: uidstat: avoid create_stat() race and blockage | bcmdhd wifi modifications | Staging/Android/binder modifications | drivers: video: samsung: implement vsync sysfs handling | s3cfb: fix S3CFB_SET_VSYNC_INT ioctl | squashed updates/changes for cgroup.c futex.c bio.c | AGNi control's installation of every boot issue fixed | Zzmoove-zanezam-optimised as new default governor
GOT 30300 Antutu score on Ivan's rom with default AGNi settings
• REGOLAMENTO • CONSIGLI SULL'UTILIZZO DEL FORUM • F.A.Q. DEL FORUM • MANUALE BBCODES •
Smartphone:
8thphloor (25-10-15)
Consigli sui settaggi?
