ChangeLog V13
New features
1. Torch Toggle (available for All 5 SystemUI)
2. Dialer section in aroma with 5 dialer choice. System default is S5 (MultiDPI 320/240) 240DPI will have Androild L look - No key separation) Screenshot Here and Here
-25% transparent key (Dialer will be full transparent but key is 25%) - MultiDPI
-50% transparent key (Dialer will be full transparent but key is 50%) - MultiDPI
-gray dialer - MultiDPI
-N2 dialer - No multiDPI
-N2 transparent dialer - No multiDPI
3. Should be more smoother scrolling (Smali level tweak)
4. snapbiz card
5. No more popout location agreement when toggle On location.
6. Ink effect with finger
7. Call/SMS block (second native support for phrase block in SMS) Setting-device-Call/Message block
8. App Op native feature (Setting-device-Dr.Ketan ROM extra)
9. 360 Rotation - applied with smali level so it will follow rotation toggle settings - It was very inconvinient to have charging pin at lower end when playing device with device connected to charging point. Now you can rotate 180 degree and charging pin on Top)
10. No increasing ring tone for S5 phone app also work along wth FSCID mod
11. S5 gallery option in aroma -extra mod - You will lose pen air edit option (when you hover pen on gallery image and pressing button give option to edit/crop etc)
12. Quickcommand short cut
Update fix
1.Floating msg app missing some option-fixed
2.Action memo have issue to not shown phone icon when you capture something from right side -fixed
3.work out done for long standing CSC feature incompatibility with wanam module. I have fixed smali level and now wanam xposed module CSC feature won't interfere with new other CSC feature
4.Floating msg stopped working issue fixed, no more activation requires.
5.3minit mod setting apk updated
6.Keyboard double space issue fixed.[
7.Ad free is to OFF by default, You can enable from Dr.Ketan Utility - Toggles
