come soluzione al brick non so, però ho notato una cosa.
oggi ho verificato la compatibilità con il Note, ed effettivamente il terminale è rilevato.
ho eseguito la stampa del PIT, e mi ha dato come risultato questo:
in "entry 0" il file associato è un emmc.imgcodice:Beginning session... Session begun with device of type: 131072 Downloading device's PIT file... PIT file download sucessful Entry Count: 15 Unknown 1: 0 Unknown 2: 0 Unknown 3: 0 Unknown 4: 0 Unknown 5: 0 Unknown 6: 0 Unknown 7: 0 Unknown 8: 0 --- Entry #0 --- Unused: No Chip Identifier: 2 (` ) Partition Identifier: 0 Partition Flags: 0 (R) Unknown 1: 0 Partition Block Size: 0 Partition Block Count: 0 Unknown 2: 0 Unknown 3: 0 Partition Name: GANG Filename: emmc.img --- Entry #1 --- Unused: No Chip Identifier: 2 (` ) Partition Identifier: 1 Partition Flags: 0 (R) Unknown 1: 0 Partition Block Size: 0 Partition Block Count: 0 Unknown 2: 0 Unknown 3: 0 Partition Name: BOOT Filename: boot.bin --- Entry #2 --- Unused: No Chip Identifier: 2 (` ) Partition Identifier: 4 Partition Flags: 1 (R) Unknown 1: 0 Partition Block Size: 8192 Partition Block Count: 40960 Unknown 2: 0 Unknown 3: 0 Partition Name: EFS Filename: efs.img --- Entry #3 --- Unused: No Chip Identifier: 2 (` ) Partition Identifier: 2 Partition Flags: 0 (R) Unknown 1: 0 Partition Block Size: 49152 Partition Block Count: 2560 Unknown 2: 0 Unknown 3: 0 Partition Name: SBL1 Filename: Sbl.bin --- Entry #4 --- Unused: No Chip Identifier: 2 (` ) Partition Identifier: 3 Partition Flags: 0 (R) Unknown 1: 0 Partition Block Size: 53248 Partition Block Count: 2560 Unknown 2: 0 Unknown 3: 0 Partition Name: SBL2 Filename: --- Entry #5 --- Unused: No Chip Identifier: 2 (` ) Partition Identifier: 5 Partition Flags: 0 (R) Unknown 1: 0 Partition Block Size: 57344 Partition Block Count: 16384 Unknown 2: 0 Unknown 3: 0 Partition Name: PARAM Filename: param.lfs --- Entry #6 --- Unused: No Chip Identifier: 2 (` ) Partition Identifier: 6 Partition Flags: 0 (R) Unknown 1: 0 Partition Block Size: 73728 Partition Block Count: 16384 Unknown 2: 0 Unknown 3: 0 Partition Name: KERNEL Filename: zImage --- Entry #7 --- Unused: No Chip Identifier: 2 (` ) Partition Identifier: 7 Partition Flags: 0 (R) Unknown 1: 0 Partition Block Size: 90112 Partition Block Count: 16384 Unknown 2: 0 Unknown 3: 0 Partition Name: RECOVERY Filename: --- Entry #8 --- Unused: No Chip Identifier: 2 (` ) Partition Identifier: 8 Partition Flags: 1 (R) Unknown 1: 0 Partition Block Size: 106496 Partition Block Count: 409600 Unknown 2: 0 Unknown 3: 0 Partition Name: CACHE Filename: cache.img --- Entry #9 --- Unused: No Chip Identifier: 2 (` ) Partition Identifier: 9 Partition Flags: 0 (R) Unknown 1: 0 Partition Block Size: 516096 Partition Block Count: 32768 Unknown 2: 0 Unknown 3: 0 Partition Name: MODEM Filename: modem.bin --- Entry #10 --- Unused: No Chip Identifier: 2 (` ) Partition Identifier: 10 Partition Flags: 1 (R) Unknown 1: 0 Partition Block Size: 548864 Partition Block Count: 1744896 Unknown 2: 0 Unknown 3: 0 Partition Name: FACTORYFS Filename: factoryfs.img --- Entry #11 --- Unused: No Chip Identifier: 2 (` ) Partition Identifier: 11 Partition Flags: 1 (R) Unknown 1: 0 Partition Block Size: 2293760 Partition Block Count: 4194304 Unknown 2: 0 Unknown 3: 0 Partition Name: DATAFS Filename: data.img --- Entry #12 --- Unused: No Chip Identifier: 2 (` ) Partition Identifier: 12 Partition Flags: 2 (R/W) Unknown 1: 0 Partition Block Size: 6488064 Partition Block Count: 23232512 Unknown 2: 0 Unknown 3: 0 Partition Name: UMS Filename: ums.rfs --- Entry #13 --- Unused: No Chip Identifier: 2 (` ) Partition Identifier: 13 Partition Flags: 1 (R) Unknown 1: 0 Partition Block Size: 29720576 Partition Block Count: 1048576 Unknown 2: 0 Unknown 3: 0 Partition Name: HIDDEN Filename: hidden.img --- Entry #14 --- Unused: Yes Chip Identifier: 1 (` ) Partition Identifier: 9 Partition Flags: 0 (R) Unknown 1: 0 Partition Block Size: 0 Partition Block Count: 0 Unknown 2: 0 Unknown 3: 0 Partition Name: Filename: Ending session... Rebooting device...
che sia possibile recuperarlo e ripristinarlo?
io la butto li.
in ogni caso il programma (versione 1.3.2, l'ultima ad oggi) sembra compatibile con il note.
chi volesse creare dei pacchetti compatibili DEVE ordinare i file in base all'ordine sequenziale delle partizioni.
es, per la versione LB1:
zimage
cache.img
modem.bin
factoryfs.img
hidden.img (che sinceramente non ho ancora capito a che serve....)
