Requirements:
- U need rom without any themes or mods install, otherwise u will end up in bootloop
- Don't flash it even over my CWM packages, bootloop
- Make a backup just in case before flashing
- If u are installing mods from 2nd post, use only with name UNIVERSAL. CWM packages over universal theme will take u to bootloop again
- Uninstall JKAY deluxe settings app (when u flash theme, latest version will be installed)
- If u have any other mods (like phone with no inc. record.full pic), remove it. U will install it latter
- REMOVE ALL MODs PLEASE. U WILL INSTALL THEM ALL, LATTER
- if u have older version of JKAY APP (JkayDeluxeSettings), please uninstall
- Patience, installation is just little bit longer
-If u still got bootloops, but ur buttons are litenin, take out battery, put it back, power ur phone. Now u should not have any more bootloops and ur theme will be installed correctly
- Download the UNIVERSAL.ZIP file from the download section below and DO NOT unzip it
- Copy the UNIVERSAL.ZIP file to your INTERNAL SD card
- Boot your phone into CWM (hold Vol Up, Home & Power Button)
Wipe cache
Wipe dalvik cache
- Select 'Install ZIP from SD Card'
- Select 'Choose Zip from SD Card'
- Then select the UNIVERSAL.ZIP file you downloaded
- Reboot
- After this you only have to enjoy
Congratulations, u just ENTERED ICS WORLD!!!
